Home > Td5 > Nanocoms
johnnyd
Nanocoms
OK I have one arriving ready for this weekend, what will/can it tell me what might be wrong with my TD5, and is it easy to use ? Does it give a readout of everything that is wrong, or do i have to run individual tests ?
JD 2008 TDCi 2.4 XS CSW
Post #244872 19th Jun 2013 4:29pm
Have a look on their web site, there were full instructions in PDF format.
I had one on my td5, easy to use, can read and reset faults, change settings on alarm, abs etc. nice units.
Post #244875 19th Jun 2013 4:38pm
johnnyd
Yeh
Nanocom has arrived Smile 2008 TDCi 2.4 XS CSW
Post #245109 20th Jun 2013 2:57pm
johnnyd
Oooh only one error reported
Airflow circuit logged low.........now what does that mean
Does a list of error descriptions exist anywhere?
JD
edit......i found this
Mass air flow (MAF) sensor/volume air flow - voltage low -> Probable cause: Wiring short to earth, supply voltage, earth connection, MAF sensor, ECM 2008 TDCi 2.4 XS CSW
Post #245175 20th Jun 2013 7:11pm
johnnyd
Ah.....still getting to grips with the Nanocom, found these other errors, given i dont have aircon (1998) do i need to do anything, is it just a reporting error?, the gearbox fault worries me though ? Although i doubt I have ABS fitted on a 1998?
NANOCOM - TD5ENG.APP - TD5 ENGINE fault file
(10,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (LOGGED).
(10,4) GEARBOX / ABS DRIVE OPEN LOAD, (LOGGED).
(10,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOA D, (LOGGED).
(14,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (CURRENT).
(14,4) GEARBOX / ABS DRIVE OPEN LOAD, (CURRENT).
(14,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOAD, (CURRENT).
Many Thanks
Post #245539 22nd Jun 2013 11:56am
landy andy
No need to do anything for those faults.
Andy
Post #245551 22nd Jun 2013 1:35pm
johnnyd
Thanks Andy.....I thought as much, but still very new to this Smile
Post #245552 22nd Jun 2013 1:40pm
landy andy
Is the new one like my old one where you need codes to go into further modes?
It seems like a silly system to me, like buying a house and only being given the keys to one of the doors, why not just allow all functions to work Question
Andy
Post #245554 22nd Jun 2013 1:45pm
johnnyd
Hi Andy
Unfortunately yes......I got 2 codes, codes 1 and 2 which is for defender and ABS I think?
It's rather odd, just want to make more money I guess?
Post #245555 22nd Jun 2013 1:53pm
johnnyd
Can you switch units in the nanocom, the speed is either misreading, or is in Kilometres?
Post #249722 7th Jul 2013 1:04pm
The speedo on my nanocom never seems to correlate to the dash speedo, although I think it just reads the pulses from the transducer, as opposed to converting to "speed"
Post #249735 7th Jul 2013 2:20pm
johnnyd
It seems to be in kph and oly accurate for 7.5 types according to this.....
http://web.nanocom.it/news_f.cfm?articolo=499
Post #249784 7th Jul 2013 7:45pm
JWL
But doesnt that give you the idea on how to calibrate your nanocom, i.e. big tyre/7.5 tyre and also 1000 revs = 1mile. I take it these notes are for the later nanocom evo and not the original nanocom 1
Post #249794 7th Jul 2013 8:16pm
johnnyd
can anyone tell me where the 'record fuelling' function is on the evo, i have read pdf's and instructions but cant see it anywhere, i need to go for a couple of minutes drive and record whats going on
Post #253624 25th Jul 2013 11:40am
johnnyd
Found it......its the 'save' icon Thumbs Up 2008 TDCi 2.4 XS CSW
Post #253661 25th Jul 2013 5:03pm
