![]() | Home > Td5 > Nanocoms |
Have a look on their web site, there were full instructions in PDF format.
I had one on my td5, easy to use, can read and reset faults, change settings on alarm, abs etc. nice units. |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Yeh
Nanocom has arrived ![]() |
Oooh only one error reported
Airflow circuit logged low.........now what does that mean Does a list of error descriptions exist anywhere? JD edit......i found this Mass air flow (MAF) sensor/volume air flow - voltage low -> Probable cause: Wiring short to earth, supply voltage, earth connection, MAF sensor, ECM 2008 TDCi 2.4 XS CSW |
Ah.....still getting to grips with the Nanocom, found these other errors, given i dont have aircon (1998) do i need to do anything, is it just a reporting error?, the gearbox fault worries me though ? Although i doubt I have ABS fitted on a 1998?
NANOCOM - TD5ENG.APP - TD5 ENGINE fault file (10,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (LOGGED). (10,4) GEARBOX / ABS DRIVE OPEN LOAD, (LOGGED). (10,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOA D, (LOGGED). (14,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (CURRENT). (14,4) GEARBOX / ABS DRIVE OPEN LOAD, (CURRENT). (14,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOAD, (CURRENT). Many Thanks JD 2008 TDCi 2.4 XS CSW |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
No need to do anything for those faults.
Andy |
Thanks Andy.....I thought as much, but still very new to this
![]() JD 2008 TDCi 2.4 XS CSW |
Is the new one like my old one where you need codes to go into further modes?
It seems like a silly system to me, like buying a house and only being given the keys to one of the doors, why not just allow all functions to work ![]() Andy |
Hi Andy
Unfortunately yes......I got 2 codes, codes 1 and 2 which is for defender and ABS I think? It's rather odd, just want to make more money I guess? JD 2008 TDCi 2.4 XS CSW |
Can you switch units in the nanocom, the speed is either misreading, or is in Kilometres?
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6202 ![]() ![]() ![]() |
The speedo on my nanocom never seems to correlate to the dash speedo, although I think it just reads the pulses from the transducer, as opposed to converting to "speed"
It seems to be in kph and oly accurate for 7.5 types according to this.....
http://web.nanocom.it/news_f.cfm?articolo=499 JD 2008 TDCi 2.4 XS CSW |
But doesnt that give you the idea on how to calibrate your nanocom, i.e. big tyre/7.5 tyre and also 1000 revs = 1mile. I take it these notes are for the later nanocom evo and not the original nanocom 1
can anyone tell me where the 'record fuelling' function is on the evo, i have read pdf's and instructions but cant see it anywhere, i need to go for a couple of minutes drive and record whats going on
Found it......its the 'save' icon
