![]() | Home > Technical > Rear A frame ball joint nut |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1863 ![]() ![]() ![]() |
Does anyone know the size of and type of spanner required for the A frame ball joint nut on a 110?
Cheers Keith |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
They are a pain to get off best option put a complete one on
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
its still needs to come out though. but yes a complete unit is easier for refit if it is the joint you are looking to change Cheers
Evsy Member Since: 03 Jul 2013 Location: Carmarthen Posts: 15 ![]() |
According to repair my land rover it's a 30mm socket on an extension bar either to ratchet or probably more use, a breaker bar.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
30mm socket.
Echo the comments about replacing with a complete fulcrum and OEM quality ball assembly. ![]() ![]() |
Thanks folks,
I bought a set of the Stahlwillie sockets off AAronmorris as 'spares' I cut about 5mm off the end of the 30mm socket, then ground a good chamfer around the drive end, now with a long extension bar I can get a good purchase on the nut, I wanted to make sure the taper itself was seated properly before I went further. I still get an annoying clunk sometimes from the back (all super pro bushes fitted) so new joint soon! Keith |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
Hmmm. Bought some sealey crows feet and the 30mm one is a loose fit and doesn't seem suitable?
Will try again in the light probably at the weekend but it isn't looking promising. Is it defo 30mm not some imperial jobbie? |
Definitely 30mm
Thank yo!u.
Would seem the 'professional' tools I brought are rubbish then ![]() |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
I just ground a slot in the old one, came off no problem!
![]() 1994 Def 90 300tdi |
Not wanting to over do it I've managed to loosen all 3 nuts (
![]() It would appear an old 3/8th worth spanner is a good fit...all the 30mm stuff I tried was a loose fit? Anyhow it's all loose and ready for a swap over when it's light again. Thanks. |
Done
![]() Bolts don't slide out very easily....if I had to do it again i'd allow an hour. If you know which end of a spanner to use perhaps 30mins? |
