Home > Technical > Rear A frame ball joint nut
ickle
Does anyone know the size of and type of spanner required for the A frame ball joint nut on a 110?
Cheers Keith
Post #243368 13th Jun 2013 10:12pm
jst
you will struggle with a spanner to get much movement.
you can get a 1/2" socket on it with an extension bar - just.
cant remember size though - 32mm? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #243386 13th Jun 2013 10:38pm
mick
They are a pain to get off best option put a complete one on Thumbs Up
Post #243393 13th Jun 2013 10:59pm
jst
its still needs to come out though. but yes a complete unit is easier for refit if it is the joint you are looking to change Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #243443 14th Jun 2013 7:18am
Evsy
According to repair my land rover it's a 30mm socket on an extension bar either to ratchet or probably more use, a breaker bar.
Post #265207 10th Sep 2013 3:23pm
Martin
Site Admin
30mm socket.
Echo the comments about replacing with a complete fulcrum and OEM quality ball assembly.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #265212 10th Sep 2013 3:34pm
ickle
Thanks folks,
I bought a set of the Stahlwillie sockets off AAronmorris as 'spares'
I cut about 5mm off the end of the 30mm socket, then ground a good chamfer around the drive end, now with a long extension bar I can get a good purchase on the nut, I wanted to make sure the taper itself was seated properly before I went further.
I still get an annoying clunk sometimes from the back (all super pro bushes fitted) so new joint soon!
Keith
Post #265410 10th Sep 2013 10:37pm
Caterham
Hmmm. Bought some sealey crows feet and the 30mm one is a loose fit and doesn't seem suitable?
Will try again in the light probably at the weekend but it isn't looking promising. Is it defo 30mm not some imperial jobbie?
Post #455960 17th Sep 2015 9:54pm
Martin
Site Admin
Definitely 30mm  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #455981 18th Sep 2015 12:50am
Caterham
Thank yo!u.
Would seem the 'professional' tools I brought are rubbish then Sad
Post #455993 18th Sep 2015 5:58am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I just ground a slot in the old one, came off no problem! Whistle 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #455999 18th Sep 2015 6:56am
Caterham
Not wanting to over do it I've managed to loosen all 3 nuts (Smile)
It would appear an old 3/8th worth spanner is a good fit...all the 30mm stuff I tried was a loose fit?
Anyhow it's all loose and ready for a swap over when it's light again.
Thanks.
Post #456262 19th Sep 2015 6:39am
Caterham
Done
Very Happy
Bolts don't slide out very easily....if I had to do it again i'd allow an hour.
If you know which end of a spanner to use perhaps 30mins?
Post #456309 19th Sep 2015 12:53pm
