![]() | Home > My Defender > Lowering Oscar |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Who's doing it? Yourself or a garage?
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Look forward to seeing it at the B&W show Claire
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 ![]() ![]() ![]() |
Doing it ourselves ...
Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230 ![]() ![]() |
Hi Claire
Hello Jason
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Sies man, lowering a Defender, what is wrong with you? ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
It's only minus 1", probably won't notice on looks, but will on driveablity after +2"
I have +2 lift on my 90 and it drives way, way better than it did on standard suspension.
It it wallows on +2 lift, then the owner put the wrong shocks/springs on. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
We have 3 90's one lowered with minus 2inch, one is on standard genuine setup and the other is on +2inch most favourite to drive is minus 2inch by far but then its down to personal opinion as always with a defender
![]() Claire you will love the new setup, -1inch is just enough, it doesnt look too low and handles a tad better CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
I was told springs were heavy duty standard and fitted at garage...no issues with the standard of work but its a two inch lift and wallows a lot..will be better when lowered.
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
Why not just take the +2 off and make it standard, rather than -1?
I don't get lowering, unless you need to get it in a garage or something. Standard is fine for everything else. It's a Defender, you can't drive it like a car. Get used to it.... and/or.... ... tune the handling with different rating combinations of springs and shocks. If the spring and shock rating is wrong for how you drive, then it will still be wrong whether it is plus 2 or minus 1. The actual height has very little to do with it. Mine has a +2 lift and doesn't 'wallow' at all as it correctly set up (no anti-roll bars either, never had them, never seen the need to). But each to his own, one thing about Defenders (as they are now, maybe not in the future) is that you can mess with them and make them do different things! ![]() Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
