Home > Maintenance & Modifications > checker plate match |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Chequer plate on rear cross member? NO
Normally put on rear cross member to either try and disguise a 'tired' ie rust box of rear cross member. OR it will help make rear cross member a rust box! Brendan |
9th Jun 2013 8:22am |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
It sounds like you have Anodised chequer plate. But as Brendan says, don't out it on the rear cross member. It can trap water and dirt behind it, and speed up corrosion. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
9th Jun 2013 8:25am |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Thanks for the cross member advice lads ill avoid the idea now. Also anodised plates is what ill try to locate for bonnet. Any idea of a good location to get the thin matting that fits between plate and paint work ?
9th Jun 2013 8:33am |
The thin matting is neoprene and is usually about 2mm thick. If you buy from somebody like Mammoth then I think they do these gaskets for all of their products.
Site sponsor Defenderbits supplies Mammoth chequer plate. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
9th Jun 2013 8:39am |
Mammoth bits, im on it thanks
9th Jun 2013 8:44am |
