Home > Maintenance & Modifications > Modular wheels
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Modular wheels
Just a quick one, is there an advantage of 15 or 16 inch modulars over alloys other than price etc?
I'm thinking of buying 5 new wheels and tyres, mainly for road use but I like the 'chunky' look of 15's with 31 inch tyres, anyone using 15's?? Any pictures?
There are some good deals on 15's, it would save about a further £100 per set of 5 over 16's.
Also, what's the best modular to get for not going rusty quickly (if there is such a thing). A nice black/grey 8 inch rim and some 265's or 31/10.5/15's preferable.
Post #241459 6th Jun 2013 3:12pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
Modulars will be an inch or so more offset (out) than alloys which means you can dial in more steering lock. Typically alloys are +33mm offset, and typically modulars (not extreme offset ones though) are either +8mm or 0mm depending on what you get.
Andy.
Post #241460 6th Jun 2013 3:17pm
Lambley
Yes, forgot to ask that, thanks Andy, I use 30mm spacers at the moment, just to fill the arches a bit. I'd like to do away with them as I've heard that they increase bearing wear.
Post #241462 6th Jun 2013 3:21pm
camelman
H There,
I've been getting my wheels and tyres recently from JCS Tyres in Nottingham J25 (at Bardills garden centre)
Has loads of stock in and competitive on price.
Speak to Charles on 0705105027, he's got a full range of modulars / alloys and most tyres.
Post #241464 6th Jun 2013 3:30pm
Lambley
^^^ yes I've been there too, nice bloke and always a deal to be had, are his modulars any good?
Post #241465 6th Jun 2013 3:32pm
familymad
Not proved though 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #241554 6th Jun 2013 8:27pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
If spacers put the bearings under excess strain, then so should wheels with different offsets, True?
I have not read any evidence to substantiate this. Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #241561 6th Jun 2013 8:39pm
^^^ I nearly typed the same thing myself, then had a think about it.....
Imagine an hub, with a standard wheel and no spacer. the centre "face" of the wheel bolted straight onto the hub.
Now imagine the same setup but with, say, a 30mm spacer. the face is now 30mm further away from the bearings than before, so that's an extra 30mm of leverage the weight of the vehicle/G forces etc are having on the bearings.
now imagine a hub with no spacer, face bolted straight to the hub, but with a wider rim. So the rim is wider, gives the good mean stance look, but the extra leverage (and I'd assume there might be a bit) is still acting straight to the hub where the face is bolted on, not an extra 30mm out.
So in my slightly blurred (nice cold bottle of Henneys cider just drunk) mind, I figure that an offset rim will give less bearing wear than a standard rim with spacers.... but slightly more than a standard setup.
Post #241578 6th Jun 2013 8:53pm
ickle
Hi Guys
Surely a 8" rim with 0 offset and a 8" rim with 33mm offset and 33mm spacers is the same beast?
BTW I'm running 8" rims with 0mm offset, better steering lock, no bearing probs, but swivel preload is critical & apparently it can start a harmonic flexing in the steering rods, Dan bars or similar are on my wish list....
Keith
Post #241589 6th Jun 2013 9:21pm
K9F
Lambley,
I run 15" wheels albeit not modulars. I wished to keep the same rolling radius as my original wheels to prevent potential fouling and throwing the speedo out. Here's a handy calculator you can play with to see what suits you in the way of boots.....
Thumbs Up
http://www.miata.net/garage/tirecalc.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #241600 6th Jun 2013 10:08pm
camelman
Hi Lambley,
I had a set of black 16x8 0 offset modulars from JCS on my last 110 for 3 years with no probs, only just sold them on recently and they were still in good nick with no rust after 3 winters.
Post #241621 7th Jun 2013 6:11am
