Home > Maintenance & Modifications > Modular wheels |
Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143 |
Modulars will be an inch or so more offset (out) than alloys which means you can dial in more steering lock. Typically alloys are +33mm offset, and typically modulars (not extreme offset ones though) are either +8mm or 0mm depending on what you get.
Andy. |
6th Jun 2013 4:17pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Yes, forgot to ask that, thanks Andy, I use 30mm spacers at the moment, just to fill the arches a bit. I'd like to do away with them as I've heard that they increase bearing wear.
6th Jun 2013 4:21pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3326 |
H There,
I've been getting my wheels and tyres recently from JCS Tyres in Nottingham J25 (at Bardills garden centre) Has loads of stock in and competitive on price. Speak to Charles on 0705105027, he's got a full range of modulars / alloys and most tyres. |
6th Jun 2013 4:30pm |
^^^ yes I've been there too, nice bloke and always a deal to be had, are his modulars any good?
6th Jun 2013 4:32pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3466 |
Not proved though 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
6th Jun 2013 9:27pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
If spacers put the bearings under excess strain, then so should wheels with different offsets, True?
I have not read any evidence to substantiate this. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
6th Jun 2013 9:39pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6041 |
^^^ I nearly typed the same thing myself, then had a think about it.....
Imagine an hub, with a standard wheel and no spacer. the centre "face" of the wheel bolted straight onto the hub. Now imagine the same setup but with, say, a 30mm spacer. the face is now 30mm further away from the bearings than before, so that's an extra 30mm of leverage the weight of the vehicle/G forces etc are having on the bearings. now imagine a hub with no spacer, face bolted straight to the hub, but with a wider rim. So the rim is wider, gives the good mean stance look, but the extra leverage (and I'd assume there might be a bit) is still acting straight to the hub where the face is bolted on, not an extra 30mm out. So in my slightly blurred (nice cold bottle of Henneys cider just drunk) mind, I figure that an offset rim will give less bearing wear than a standard rim with spacers.... but slightly more than a standard setup. |
6th Jun 2013 9:53pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Hi Guys
Surely a 8" rim with 0 offset and a 8" rim with 33mm offset and 33mm spacers is the same beast? BTW I'm running 8" rims with 0mm offset, better steering lock, no bearing probs, but swivel preload is critical & apparently it can start a harmonic flexing in the steering rods, Dan bars or similar are on my wish list.... Keith |
6th Jun 2013 10:21pm |
Lambley,
I run 15" wheels albeit not modulars. I wished to keep the same rolling radius as my original wheels to prevent potential fouling and throwing the speedo out. Here's a handy calculator you can play with to see what suits you in the way of boots..... http://www.miata.net/garage/tirecalc.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Jun 2013 11:08pm |
Hi Lambley,
I had a set of black 16x8 0 offset modulars from JCS on my last 110 for 3 years with no probs, only just sold them on recently and they were still in good nick with no rust after 3 winters. |
7th Jun 2013 7:11am |
