Home > Technical > New Defender 90.....Placing/Location of dash switches?
Pickles
Just in the process of ordering a new "90".
We have a few options including Cold Climate Pack, driving Lights etc. I was just wondering is there any specific location/function for the various switch locations provided, or are the switches not in any particular location, ie..where would the driving light switch be located?...I've heard..on the far RHS?
Any pics of your factory switch locations?
Cheers, Pickles.
Post #240896 4th Jun 2013 2:33am
mobilecentre
The switches all fit in specific places and cannot be changed without shaving off the locating tabs.
Post #240912 4th Jun 2013 8:11am
kmac
Re: New Defender 90.....Placing/Location of dash switches?
Cheers, Pickles.
Below is an XS spec dash - there is one blank which could be used for DRLs or whatever (one with the heated seat switch in the top row - I've used this as a decoy for something else
Cold climate pack - sounds grandiose - what do you get in it?
Post #240929 4th Jun 2013 10:12am
Pickles
Don't know about "grandoise"!!!, but, Cold Climate Pack..in Aus....= heated seats, & heated front screen!!?
Cheers, Pickles.
Post #240932 4th Jun 2013 10:16am
kmac
Okay to answer your questions then:
1) Light switch is on a stalk on steering column
2) heated seat switches - bottom row in pic on either side of Aircon switch
3) Heated windscreen - top row in pic (left of hazard lights switch which is below the clock)
Don't believe there are factory options to change the location of switches (but I guess there is nothing to really stop you moving them around yourself though I'm not sure why you would want to do that.
Post #240934 4th Jun 2013 10:20am
Pickles
So, there will be room for the Driving Light switch?
Cheers, Pickles.
Post #240941 4th Jun 2013 11:22am
K9F
Yes! But that's your lot! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #240942 4th Jun 2013 11:26am
Pickles
No worries then,.....'cause that's all I need!
Thanks, Pickles.
Post #240943 4th Jun 2013 11:30am
