![]() | Home > Technical > New Defender 90.....Placing/Location of dash switches? |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
The switches all fit in specific places and cannot be changed without shaving off the locating tabs.
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Below is an XS spec dash - there is one blank which could be used for DRLs or whatever (one with the heated seat switch in the top row - I've used this as a decoy for something else Cold climate pack - sounds grandiose - what do you get in it? ![]() Click image to enlarge |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
Don't know about "grandoise"!!!, but, Cold Climate Pack..in Aus....= heated seats, & heated front screen!!?
Cheers, Pickles. |
Okay to answer your questions then:
1) Light switch is on a stalk on steering column 2) heated seat switches - bottom row in pic on either side of Aircon switch 3) Heated windscreen - top row in pic (left of hazard lights switch which is below the clock) Don't believe there are factory options to change the location of switches (but I guess there is nothing to really stop you moving them around yourself though I'm not sure why you would want to do that. |
So, there will be room for the Driving Light switch? Cheers, Pickles. |
Yes! But that's your lot!
![]() Treat every day as if it is your last....one day you will be right!! |
No worries then,.....'cause that's all I need! Thanks, Pickles. |
