Home > Technical > Washer Jets
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Washer Jets
Hi. advise appreciated please
TD5 windscreen washer jet not delivering to windscreen. The pump is making the desired noise and I have taken the jet (thingy Razz ) off just in case it is blocked. So no water coming through, any help on what to check next appreciated. I have tried to track the journey of the plastic tube but that aint that easy.
Anyway, any tips appreciated, SS Sweatysock
110 CSW TDCI (Puma) 2007
Post #238748 26th May 2013 7:36pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Obvious one first. There is water in the reservoir? Rhubarb and custard let fly with their secret weapon.
Post #238749 26th May 2013 7:40pm
ARC99
Rolling with laughter
Post #238752 26th May 2013 7:45pm
K9F
Is there any evidence of water underneath the vehicle when you operate it? If not take the outlet pipe off as close as you can to the pump to see if the pump is still delivering pressure, if not the pump may be knackered. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #238755 26th May 2013 7:58pm
GUM97
There may be a split in the hose? Or maybe a blockage in the Non-Return valve situated near the washer bottle on the hose? An engine to TDi for!
Post #238759 26th May 2013 8:03pm
sweatysock
question - can pump still make the noise as it is functioning without working ? excuse if this is obvios, SS Sweatysock
Post #238767 26th May 2013 8:22pm
K9F
Yes if impellor is sheared or detached motor will still turn but produce no pressure in the system. Thumbs Up
Same if you've a split/detached feed pipe the water should run out under the vehicle somewhere. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #238771 26th May 2013 8:25pm
sweatysock
I knew that... Shocked , fantastic, will check tomorrow, ta Sweatysock
Post #238774 26th May 2013 8:30pm
K9F
Good luck... Thumbs Up Let us know how you get on. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #238846 26th May 2013 10:55pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I had the same thing on my TD5, turned out to be a little non return valve just before the pipes disappear into the bulkhead, I removed it and drilled right through it and refit, been perfect eve rsince Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #238868 27th May 2013 8:05am
sweatysock
By way of an update. Established no blockages from investigating tubing I could locate, in particular behind bulkhead. Given truck is newly purchased, decided to take back to garage rather than strip anything down to look further.
Garage (MM 4x4 near Worcester) have been great to deal with (moved from my previous local preferred garage due to some issues...no more said Twisted Evil ) and could not have been more pleased with their reaction to this, albeit, minor issue.
Anyone else had experience from them ? SS Sweatysock
Post #239362 28th May 2013 8:50pm
GUM97
MM 4x4 have always been great for me when buying parts, although I've never used them for servicing (too far away Laughing ) Thumbs Up An engine to TDi for!
Post #239363 28th May 2013 8:58pm
landyman37
Just don't buy a non gen fuel pump off them for a td5
Post #241523 6th Jun 2013 8:27pm
