![]() | Home > Td5 > Aircon question |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1388 ![]() ![]() ![]() |
more a switch, similar to the headlight adjustment one....and there's 2 of them..right by drivers right knee. Putting Dreams on Drives at JLR Solihull..
Ahh right, I've seen the two by the drivers knee on a google search but I couldn't make out from any of the pics if there was a seperate switch on the centre dash bit to switch it on and off like on the puma
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1133 ![]() ![]() |
No, its a completely separate unit from the main heater. 2 rotary switches, one controls the fan, with 3 positions. The other controls the aircon pump, with setting 1 2 and 3.
It is a bit primitive and noisy, but works well. In the rain, I always keep the ac on position 1 even when using the heater to keep the steamed up windows at bay! 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
That's great thanks
![]() Ray |
Brucey Member Since: 18 Jul 2012 Location: Warsaw, Poland Posts: 61 ![]() ![]() ![]() |
Has anyone figured out how to stop the aircon condenser leaking all over the passenger floor instead of the water going down the little pipe whihc drips over the chassis outrigger? I have tried to fill joints using mirror to see where leaks are, but so far no luck. Is there an easy solution?
Chris Defender 110 DC converted Auto BMW R1200GS BMW F650GS Dakar |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
There's curd in the drainage pipe. Just clear it out n it should be back to normal. The question is how to remove that pipe, easily. The defender has migrated, leaving the owner behind.
Unfortunately there is no blockage, first thing that i checked. The pipe comes off easily.
It is leaking at the joint beteeen front and back platic case where the condenser pipes enter the plastic 'box'. If that makes any sense. Next step is use a dremmel to cut a playing card size hole in the front of the plastic case to have a look from the inside....... We will see. Chris Defender 110 DC converted Auto BMW R1200GS BMW F650GS Dakar |
