Home > Td5 > Aircon question
mk1collector
Aircon question
Hello all, on td5's with aircon is there an "ac" button on the dash itself or are all the controls including any on/off switch on the lower aircon dash section? Pics would be greatly appreciated too Thumbs Up
Ray
Post #238022 23rd May 2013 2:52pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
more a switch, similar to the headlight adjustment one....and there's 2 of them..right by drivers right knee. Putting Dreams on Drives at JLR Solihull..
Post #238024 23rd May 2013 2:57pm
mk1collector
Ahh right, I've seen the two by the drivers knee on a google search but I couldn't make out from any of the pics if there was a seperate switch on the centre dash bit to switch it on and off like on the puma
Post #238029 23rd May 2013 3:19pm
Gareth
No, its a completely separate unit from the main heater. 2 rotary switches, one controls the fan, with 3 positions. The other controls the aircon pump, with setting 1 2 and 3.
It is a bit primitive and noisy, but works well. In the rain, I always keep the ac on position 1 even when using the heater to keep the steamed up windows at bay! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #238036 23rd May 2013 3:54pm
mk1collector
That's great thanks Thumbs Up
Ray
Post #238045 23rd May 2013 4:39pm
Brucey
Poland 2004 Defender 110 Td5 DCPU Auto Java Black
Another aircon question
Has anyone figured out how to stop the aircon condenser leaking all over the passenger floor instead of the water going down the little pipe whihc drips over the chassis outrigger? I have tried to fill joints using mirror to see where leaks are, but so far no luck. Is there an easy solution?
Chris Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #239147 28th May 2013 10:09am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
There's curd in the drainage pipe. Just clear it out n it should be back to normal. The question is how to remove that pipe, easily. The defender has migrated, leaving the owner behind.
Post #240381 2nd Jun 2013 2:22am
Brucey
Unfortunately there is no blockage, first thing that i checked. The pipe comes off easily.
It is leaking at the joint beteeen front and back platic case where the condenser pipes enter the plastic 'box'. If that makes any sense. Next step is use a dremmel to cut a playing card size hole in the front of the plastic case to have a look from the inside.......
We will see.
BMW R1200GS
BMW F650GS Dakar
Post #242555 10th Jun 2013 7:20pm
