![]() | Home > My Defender > What Did You Do In Your Defender Today |
Knot Yet Member Since: 01 Mar 2010 Location: West Sussex Posts: 197 ![]() ![]() ![]() |
Thanks K9F - very interesting and as you say does look good
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 ![]() ![]() ![]() |
Used the air con
![]() 55 TD5 110 CSW Special Vehicle |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2674 ![]() ![]() ![]() |
Went to the Land Rover Experience course on Saturday. SWAMBO did the driving
JMS Member Since: 05 Mar 2010 Location: Isle of Wight Posts: 40 ![]() ![]() ![]() |
Reversed over my Iphone....
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 ![]() ![]() ![]() |
Well done
![]() 110 HCPU Tipper |
+ 1^10 |
Nice pics Naks,
Good example of articulation capabilities! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Yes, and you know what happened after that? See http://www.defender2.net/forum/topic2749.html?highlight= |
![]() ![]() Sorted now I trust? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Actually not, the banging noise only started after we finished the trail and were heading back to lunch. The articulation must have started the dislodging? Yep, all sorted, I crawled under the landy, unbolted the mounting, pushed the rubber back in, and bolted everything back. I also checked the other mounting, and the bolts were not as tight, since I could tighten then further - probably been like that since it left the factory. |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Today, I finnaly got my @rse into gear and fitted my Defender2.net sticker (only taken 5 months
![]() ![]() ![]() Glyn :sheep: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by Glynparry25 on 11th Mar 2010 11:00pm. Edited 2 times in total |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
nice sticky rear glyn
Fitted my cargo barrier, nearly gave up twice. No wonder L/R insist it is a long job (forget how many hours) the tolerances are rubbish but it took me about 3 in total with some profanity and grazed knuckles
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge feels secure. Now off to dig out a MOLLE pouch for my jetboil and brew kit :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 55 TD5 110 CSW Special Vehicle |
![]() ![]() ![]() 110 HCPU Tipper |
