Page 555 of 1392 <123 ... 554555556 ... 139013911392>
excossack
Picked up the following parts for the Landy
Part number
CRC1250L
NTC9543L
Still need to get SL510032, non in stock and not worth ordering for just a couple so will tag it onto another order at some point. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #261820 28th Aug 2013 8:46am
JWL
After a few days of intermittant starting faults today was the day it decided to say NO. The root cause is a leaking fuel pressure regulator(in hand waiting for bits to arrive) which is doing its usual thing of dripping onto the starter. Got caught out big time today ending up having to push start the 110 to get home, straight after parking out with the tools, bridging across the solonoid confirmed nothing wrong with the motor so with a bit of contortionism I took the cover off the solonoid, pulled out the plunger and lo and behold the thing was as black as the Ace of Spades. Liberal dosing of contact cleaner on the plunger and internal contacts, put it all back together and instant starting again. All in all it took me about 20 minutes from getting the tools out and cleaning them up and putting them away.
Post #262318 30th Aug 2013 12:00am
Applied my new stickers:
Post #262642 31st Aug 2013 4:50pm
Sockpuppet
Nice, I reckon dark green version would also work very well with Keswick.
Ok, not yet my land rover but went over to the dealers to sort out some paperwork ready for collection on Thursday.
Finally got to see it, from a distance and through some locked gates - though I might be picky I reckon that number plate could do with moving half an inch to the left! Whistle
Post #262657 31st Aug 2013 5:35pm
^^^^ Excellent!! Thumbs Up
I finally sorted the (non existant) brakes out on the 110. after fitting new discs and calipers on the front, and new pads on the back, I had naff all braking.
Then after swapping the servo and vacuum pump, it turned out to be a leaking O ring between the master cylinder and servo.
Got some instant gasket in there. nicely sealed now! Whistle
Post #262659 31st Aug 2013 5:37pm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Applied my new sticker:
 My Disco 'best bits'
Defender 110 XS CSW 2013
Post #262663 31st Aug 2013 5:48pm
excossack
Fitted the dual USB and 12v socket from MobileCentre to the mudstuff dash
Regards
John M0VAZ
Post #262665 31st Aug 2013 5:57pm
Vizsla
Finally got around to taking all four wheels off and cleaning the rear faces, springs etc etc and spraying the bits I didn't get at earlier in the week when using the Dinitrol Very Happy
Resisted washing it until I can spend an appropriate amount of time to do it properly.
Post #262668 31st Aug 2013 6:19pm
GUM97
Spent today fitting all 4 new mudflaps Mr. Green Then some new side steps Mr. Green Took a lot longer than anticipated! An engine to TDi for!
Post #262672 31st Aug 2013 6:31pm
JWL
Seal kit on the fuel pressure regulator, now all the diesel I buy to put in the tank goes through the injectors not all over the back of the engine Rolling Eyes
Post #262677 31st Aug 2013 6:38pm
I fitted one of those seal kits a couple of months ago.
fingers crossed, it's still stayed nice and dry. Thumbs Up
Post #262681 31st Aug 2013 6:49pm
Loaded up the 110 with bikes and hitched the 'van up to return from holiday and the Great Dorset Steam Fair. Lots of Defenders there Thumbs Up
The Defender performed faultlessly and the trip was without incident, except for a mild panic when faced with a low bridge in Salisbury Shocked This resulted in a quick stop in a layby and a hasty session with a tape measure to check the height over the bikes on the roof. Fortunately, they were just over eleven feet and the bridge was thirteen Laughing Darren
Post #262684 31st Aug 2013 7:01pm
Welly911
Puma seats fitted
Had some fabrication done here in Dubai at Saluki Motorsport to get a set of 2011 Puma/TDCI rear seats put into my TD5 110DC. Awesome job! Still amazed at the additional weight of the seats! Might have justification for an Alive re-map now.....
Post #262692 31st Aug 2013 7:24pm
JWL
@ Diesel Jim, this is the second time in 2 years but I'm not overly convinced as I did get a drip on the bleed sequence. I've a feeling that the valve body itself is the problem but at least it's not constantly dripping as it has been. I should have gone the extra mile and got a new valve instead of being a cheapskate, time will tell Rolling Eyes
Post #262717 31st Aug 2013 8:20pm
WarPig
Ha ha, been there and got that tshirt. Its nerve racking isnt it. I now have all the heights of my caravan, LR, roof bars, roof box & bikes written on the inside of the windscreen in both centimetres & inches.
When I know Im going to be driving with the bikes on the roof I often drive the route on Google street view first, checking for bridges. Sad aint it!! Confused
Post #262730 31st Aug 2013 8:36pm
