Page 507 of 1394 <123 ... 506507508 ... 139213931394>
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
boode wrote:
Finished the new look front on my Td5.
Installed "Series Look" light surrounds to make headlight bulb changes much easier.
Now its just 8 screws to remove to acces the headlights. Previously the mobile center side lights needed removing which, with their bolts inside the wings, required inner wing removal or exrteemly thin, long and flexible arms - not a 5 minute job.
The surrounds are Aluminium and came from Brendan / Leeds
Looks good Thumbs Up
Where did you get the bumper from with the four lights Question Defender 110 TDCi XS SW
Range Rover Sport HSE
Post #236447 17th May 2013 8:48pm
it's a devon 4x4 HD bumper
Gavin -your truck looks great .. Love the fire engine red Thumbs Up
Post #236449 17th May 2013 8:53pm
collected my hannibal 110 rack freshly powder coated satin black, looks awesome.
also, had the dog guard and blanchards snow cowl coated at the same time.
Post #236451 17th May 2013 8:55pm
PK1
Many thanks Thumbs Up Defender 110 TDCi XS SW
Post #236452 17th May 2013 8:58pm
Cleaned the green 110 inside and out
Post #236640 18th May 2013 5:57pm
LR90XS2011
drove to West Wales visited some relatives whom helped me finally fit the Group buy Bonnet Hinges and drove back again, a rally and classic car show going on in Welshpool so some interesting machinery about DEFENDER 90 TDCI XS,
Post #236667 18th May 2013 7:47pm
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Bit of a play Laughing
[/URL][/img]
[/URL][/img]
Post #236672 18th May 2013 8:02pm
Defender-Stu
Ha ha just got home and cleaned the 90 so have to get some pics together tomorrow as long as the weathers nice lol, but would be good if the ice came out then pics of 2 LE defenders Whistle Thumbs Up
Post #236681 18th May 2013 8:29pm
Spruce Pirate
Scotland 2013 Defender 110 Puma 2.2 HT Zambezi Silver
Fitted a Bulldog lock to the back door after getting broken into a couple of nights ago. Mad Dirty Deeds - Done Dirt Cheap
Post #236684 18th May 2013 8:31pm
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
Went to 80's festival in Cookham. All 4x4 were parked in special field with long grass.
Left early to avoid 4000 other cars leaving through one gate.
Last act was Tony Hadley, a lot of people were leaving then....
Great day out Very Happy 110XS CSW TD5.
Post #236745 18th May 2013 11:59pm
JWL
Got round to replacing a UJ on the rear propshaft. That one has lasted about 18months, not too bad for an "el-cheapo", especially one without a grease nipple. Two caps were still all still full of grease whereas the other two were as dry as a bone and giving movement in the wrong direction.
Eventually found the cause of that annoying rattle I've suffered for months. It turned out to be the spring retainer on the nearside rear. I have 130 assister springs inside the main springs and the smaller springs sit on a dish that is held off the bottom base plate by spacers and by doing so allow the use of the original main spring retainer. The retainer is just a strip of steel 30mm wide with holes that match up with holes on the base plate. This strip had bent out of shape and was just rattling about and driving me bonkers.
Adjusted the hand brake at the drum after a quick inspection of the shoes and ended up going to the rescue of a mate with a Disco1 that he couldn't start. It turned out to be the ignition switch, not the electrical side but the lock barrel. The key would go in, turn through positions 1 and 2 but not go that bit further to the start position that springs back when you let the key go. My old Disco2 had a similar problem as has my 110, it usually begins with sporadic difficulty in getting the key to turn in the lock then one day you just won't be able to turn it at all. It will be more noticable with a well used key and the reason is that the key will start to wear and will not operate all the tumblers in the lock properly. My 110 came with 2 sets of keys, one set of which were like new so I got a copy made off that one and use the copy and touch wood never had a problem since. With my mates Disco I did the same as my old Disco2, I took out the lock barrel and took out some of the tumblers, put it all back together and away it went!
All fine and dandy, apart from the fact that I couldn't turn the damned ignition off position 1 Embarassed I had turned the ignition on when trying it without the barrel and hadn't turned it all the way off when I replaced the barrel. So all off again to sort it and now he can use it untill he gets a new lock.
Post #236747 19th May 2013 12:36am
LR90XS2011
got up early to a twiddly thumbs morning, so I peeled of the defender sticker from the rear panel and fitted some 3d DEFENDER letters that match the Bonnet LAND ROVER that I purchesed about 12 months ago from B.O.Bs . Read a thread on here about this before that has inspired me, I found my sticker just peeled off after lifting 1 corner with a craft knife so no need for a hot air gun or hair drier. Very happy with the result much more up market. DEFENDER 90 TDCI XS,
Post #236755 19th May 2013 7:29am
Offroad-Tec
Germany
Small trip to fürsten forest
Hello,
yesterday we had a small trip to fürsten-forest (near Osnabrück/ Germany). We needed a small timeout for new ideas! Smile
Greetings- Markus
Post #236836 19th May 2013 2:58pm
Green Machine
LR90XS2011 wrote:
I peeled of the defender sticker from the rear panel and fitted some 3d DEFENDER letters that match the Bonnet LAND ROVER that I purchesed about 12 months ago from B.O.Bs.
Pics? Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #236837 19th May 2013 3:04pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Trip down to Beaulieu auto jumble and the sort out
Nice early start first in the car park
This year loads of half decent stuff as well but a lot less stalls all round
Up untill now I only had one vice.......... but not any more got his there for £20 Rolling with laughter Rolling with laughter
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #236848 19th May 2013 3:44pm
