Page 29 of 1393 <123 ... 282930 ... 139113921393>
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
TACK wrote:
Raised the centre cubby box by 40mm, much better now it is raise, more like my old D3 now Rolling with laughter also fitted a gove box on the passenger side Whistle 1 bit to sort then its finished Mr. Green
Tony,
Can you take some photos. Well interested in raising the cubby!!
Ian Thumbs Up
Post #36194 13th Jul 2010 9:15pm
TACK
Ian, can take a pic later, but easy enough.
There are 4 bolts which hold the box down, 2 in the cubby box and the other 2 you will see by lifting out the plastic cup holder section. undo these, lift the cubby box out, its nice and light made of MDF Confused
You will see LR have used soft wood timber battens to level the box with the floor pan, these are glued to the underside of the cubby box.
I used 2 additional lenghts approx 300mm of 2x1.5" timber, almost like packers, lined them up, drilled holes through the new battens with the holes lined with the cubby box and bolted my new batten to the original holes made by LR in the floor pan, then screwed the cubby box back into my new timber battens, thus raising it up. Simple. Made new holes in the bootom of the cubby box as your old hole alignemnt has been used by the batten, unless you have some longer bolts kicking around Thumbs Up
Also gives a secret stash place under the cubby box beacuse there is now a void. Well it was a secret Banging Head
Post #36261 14th Jul 2010 12:40pm
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
"What did you do in your defender today"
NOTHING................the wife took it to work! Evil or Very Mad Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #36267 14th Jul 2010 1:56pm
Hey Tack what do you keep in the Secret place
Post #36281 14th Jul 2010 4:15pm
WarPig
Porn mags??
Post #36297 14th Jul 2010 7:37pm
TACK
WarPig wrote:
Porn mags??
Porn mags will fit, but not got mud rails so can't strech legs out Rolling with laughter
But the utility belt with 300mm dildo fits much better. Or good stash for passports and doc's if overland travelling, might not be so suspect if searched Exclamation
Post #36319 14th Jul 2010 10:06pm
discocuzzy
But you have your nice A4 pocket for your training manuals Tony...i recon there should be enough room for "Dorris"...your portable lover.
She can also be inflated from under the passenger seat when you have one of those "it aint gonna suck itself" moments Whistle You cannot teach stupid people to do clever things
Post #36327 14th Jul 2010 10:48pm
AndrewS
Made a battery clamp to hold the three battery's under the second row seats in place 130's have feeling's as well you know Smile
Post #36334 14th Jul 2010 11:12pm
K9F
Three batteries? What you thinking of digging up a corpse and trying to jump start it back into life again? Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #36342 14th Jul 2010 11:57pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
You need 2 batteries for welding the other is for the defender. Whistle Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #36348 15th Jul 2010 7:36am
AndrewS
No the defender already has 2, the 3 are for the 1500w inverter Thumbs Up 130's have feeling's as well you know Smile
Post #36373 15th Jul 2010 1:31pm
3WHouse
Russia 2007 Defender 110 Puma 2.4 SW Java Black
I use the inverter 1500. There are no problems..
http://i058.radikal.ru/1007/50/1a1294b1aa1d.jpg Def`s 90 & 110 Monochrome.
You can go fast i can go anywhere.))
http://www.offroadpower.ru/
Post #36380 15th Jul 2010 5:51pm
alanhid
Fitted new stainless steel bonnet hinge bolts..................my first job on it! Life is not a rehearsal!
Post #36389 15th Jul 2010 8:57pm
alantd
Been busy (what else is paternity leave for?):
Fitted my 2" receiver - very smart.
Made a frame for my under-cubby safe to raise it slightly and fitted that - the dogs danglies
Fitted my rear parking sensors - a must-have fit for everyone at £20
Stripped my sankey down completely, waxoyled the chassis and bottom of the tub, serviced the brakes, fixed the wiring and painted the tub - bomb proof - it'll outlast me
Oh, and had a kid Very Happy One that started out as a 2.4 TDCi 110 XS
Post #36668 20th Jul 2010 9:07pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
hi
please can you tell me which parking sensors you fitted.
Kid - just noticed that, why do you want a baby goat Laughing huge congrats Very Happy
thanks BM52
Post #36672 20th Jul 2010 9:58pm
