Home > Technical > Canopy rope cleats |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2875 |
Just hole for the rope
29th Apr 2013 9:39pm |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
pics of rope cleats
land rover part number RRC8002 |
30th Apr 2013 8:06am |
Also try Holt Allen HA 4077A the fixing hole centers are in-portent
30th Apr 2013 8:32am |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1751 |
Thanks for the pics but I wondered if these were fitted on the DC and if so, where?
30th Apr 2013 9:12pm |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 363 |
They are on mine. They are level with the canopy openings at the back.
They may not be on the new versions that have zip canopies! I can take a pic in the morning if you want? 2006 Defender Double Cab- Zambezi Silver |
30th Apr 2013 10:13pm |
MY13:
Click image to enlarge |
1st May 2013 2:58am |
Not got those galv hooks on mine - not even marks or holes where they could hae been
1st May 2013 9:36pm |
So what do the side ropes tie off to? They are only pop riveted on - took off the plastic blanking cowls yesterday and was disappointed to see they hadn't even used a washer to spread the load a bit. If you wiggle the cleat there's quite a point loading at the fixing point. Will be drilling mine out and replacing with some small bolts and appropriate penny washers or spreader plate. [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
2nd May 2013 7:29am |
Ropes were tied off around hooked strap which I suspected wasn't right
2nd May 2013 8:19pm |
So was your's a conversion to a DCPU rather than leaving the factory as one?
2nd May 2013 11:04pm |
Definitely a factory DC, had it checked on LR mainframe prior to purchase. I suspect hoods are put on at dealership as part of PDI and the cleats were possibly forgotten at the factory Bought some cleats today to match yours at great expense- genuine parts £5.60 for the pair
3rd May 2013 7:28pm |
galv hooks ones or RRC8002 ?
3rd May 2013 7:34pm |
As supacats picture |
3rd May 2013 7:39pm |
I think it's the 7th digit/character of the VIN - it should be an "F". Not thought about DCPUs leaving factory with hood not fitted but can see the logic if that is the case. |
3rd May 2013 8:31pm |
