![]() | Home > Technical > Canopy rope cleats |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Just hole for the rope
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
pics of rope cleats
![]() land rover part number RRC8002 ![]() |
Also try Holt Allen HA 4077A the fixing hole centers are in-portent
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
Thanks for the pics but I wondered if these were fitted on the DC and if so, where?
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 372 ![]() ![]() ![]() |
They are on mine. They are level with the canopy openings at the back.
They may not be on the new versions that have zip canopies! I can take a pic in the morning if you want? 2006 Defender Double Cab- Zambezi Silver |
MY13:
Not got those galv hooks on mine - not even marks or holes where they could hae been
So what do the side ropes tie off to? They are only pop riveted on - took off the plastic blanking cowls yesterday and was disappointed to see they hadn't even used a washer to spread the load a bit. If you wiggle the cleat there's quite a point loading at the fixing point. Will be drilling mine out and replacing with some small bolts and appropriate penny washers or spreader plate. [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Ropes were tied off around hooked strap which I suspected wasn't right
So was your's a conversion to a DCPU rather than leaving the factory as one?
Definitely a factory DC, had it checked on LR mainframe prior to purchase. I suspect hoods are put on at dealership as part of PDI and the cleats were possibly forgotten at the factory
galv hooks ones or RRC8002 ?
As supacats picture |
I think it's the 7th digit/character of the VIN - it should be an "F". Not thought about DCPUs leaving factory with hood not fitted but can see the logic if that is the case. |
