![]() | Home > Td5 > Strange noise on overrun. |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Propshaft journals.
Check with wheels chocked, out of gear and handbrake off. Rear of front shaft most likely. ![]() |
| 3216andy Member Since: 22 Oct 2011 Location: south lincolnshire Posts: 18
Any freeplay in the journals or the flange fastenings.
Spot on Laurie
Easy job to tackle? It just gets louder, not faster. |
Just go underneath and try to move each end of each shaft.
A push-pull motion should be repeated at approximately 90 degrees to the first attempt. If everything seems secure there are several other possibilities. ![]() |
Sorry, that last post was not clear, I been and checked, there is play, rear of front shaft as you predicted.
Is it easy to repalce? It just gets louder, not faster. |
You need to remove the propshaft complete.
A replacement universal joint is around £30 (OEM ones come in a Britpart box!), best to replace both while it's out. If you're unsure how to do it a local garage will charge you for about an hour. Once you've got the shaft out engage the difflock and take it for a drive. If you still get the noise then that's not your problem. Don't forget to take the difflock out after you've put the repaired shaft back in. Alternatively, a new propshaft will cost about £160. ![]() |
Thank you Laurie, most helpful.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8364
i would GKN hardy spicer ones if you are doing UJ prop joints. bar far the best quaility for the money. Bearmach do them. Its a pretty easy job - once you have seen how to do it. have a look in the tech archive on lR4x4 there is bound to be a write up on there about it. Cheers
Britpart ones are GKN as far as I know.
I've just had my front prop done. ![]() |
all is good then.
£30 seems steep though. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
For info, I bought a pair of genuine GKN HD ujs (oversize bearings) for my Puma DC rear prop a couple of weeks ago from Dingocroft for about £19 each.
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Heavy duty uj from bailey Morris is £25
Andy |
I was judging the price by Ebay prices.
Haven't had the bill from my garage yet. ![]() |
