Home > Td5 > Strange noise on overrun.
3216andy
United Kingdom 1999 Defender 90 Td5 Heritage LE Atlantic Green
Started yesterday, on over run there is a metallic rattle/chatter, goes under load.
Where do I start the investigations? It just gets louder, not faster.
Post #230195 24th Apr 2013 5:38pm
Laurie
Propshaft journals.
Check with wheels chocked, out of gear and handbrake off.
Rear of front shaft most likely.
Post #230197 24th Apr 2013 5:41pm
3216andy
Embarassed Probably blindingly obvious to those in the know, but what am I checking for exactly? Embarassed It just gets louder, not faster.
Post #230199 24th Apr 2013 5:49pm
Laurie
Any freeplay in the journals or the flange fastenings.
Post #230200 24th Apr 2013 5:55pm
3216andy
Spot on Laurie Thumbs Up
Easy job to tackle? It just gets louder, not faster.
Post #230208 24th Apr 2013 6:09pm
Laurie
Just go underneath and try to move each end of each shaft.
A push-pull motion should be repeated at approximately 90 degrees to the first attempt.
If everything seems secure there are several other possibilities.
Post #230219 24th Apr 2013 6:33pm
3216andy
Sorry, that last post was not clear, I been and checked, there is play, rear of front shaft as you predicted.
Is it easy to repalce? It just gets louder, not faster.
Post #230233 24th Apr 2013 7:27pm
Laurie
You need to remove the propshaft complete.
A replacement universal joint is around £30 (OEM ones come in a Britpart box!), best to replace both while it's out. If you're unsure how to do it a local garage will charge you for about an hour.
Once you've got the shaft out engage the difflock and take it for a drive. If you still get the noise then that's not your problem. Don't forget to take the difflock out after you've put the repaired shaft back in.
Alternatively, a new propshaft will cost about £160.
Post #230243 24th Apr 2013 8:13pm
3216andy
Thank you Laurie, most helpful. Thumbs Up It just gets louder, not faster.
Post #230471 25th Apr 2013 5:12pm
jst
i would GKN hardy spicer ones if you are doing UJ prop joints. bar far the best quaility for the money. Bearmach do them. Its a pretty easy job - once you have seen how to do it. have a look in the tech archive on lR4x4 there is bound to be a write up on there about it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #230473 25th Apr 2013 5:15pm
Laurie
Britpart ones are GKN as far as I know.
I've just had my front prop done.
Post #230497 25th Apr 2013 7:01pm
jst
all is good then.
£30 seems steep though. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #230526 25th Apr 2013 8:49pm
For info, I bought a pair of genuine GKN HD ujs (oversize bearings) for my Puma DC rear prop a couple of weeks ago from Dingocroft for about £19 each.
Post #230544 25th Apr 2013 9:26pm
landy andy
Heavy duty uj from bailey Morris is £25
Andy
Post #230545 25th Apr 2013 9:27pm
Laurie
I was judging the price by Ebay prices.
Haven't had the bill from my garage yet.
Post #230550 25th Apr 2013 9:40pm
