![]() | Home > Technical > Defender Diff Lock Mechanism |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Hi guys,
As far as I know that when you engage the diff lock either high or Low, one front and one rear wheel work simultaniously at a time. Please correct me if i am wrong. Also I would like to know whether defender diff lock mechanism is same as other models as when engaged 4WD lever to H4 and L4 of Toyota, Mitshubishi etc? Cheers. ![]() ![]() Diluk |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
Think of it in terms of this;
When the (centre) diff lock is engaged, it effectively locks the front and rear propshafts together - half the torque will go to the front axle, and half to the rear. From there, power is split between the wheels on each axle - so you are correct in saying that engaging the diff lock only guarantees 2WD - one wheel on each axle. My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
he said the same thing. with diff lock selected you will guarantee that 1 front wheel and 1 rear wheel will turn; whether or not you have traction control. if you have traction control it will apply the brakes to spinning wheel when the opposite wheel on the same axle is not spinning (or at different rates) which will have the effect of transferring torque to the spinning wheel. Alternatively your axle diffs could be fitted with limited slip differentials or a fully locking differential which provides for a more mechanical means of meeting the same objective. |
correct
Yes its the same. Those vehicles may also have a 2WD mode which the defender doesnt have (its always 4WD). The way you select combinations of high/low/lock will obviously depend upon model etc. |
Thanks everyone for the posts. Cheers.
Just want to share my idea on full time 4WD with you guys. It has worked even well on the sandy roads with out wanting to engage diff lock. Also LR manual says not to use centre diff lock while turning the steering. So sometimes I use the full time 4WD with muddy curved roads as you have to turn the steering! |
