Home > Technical > TD5 EGR Blanking on 1998 TD5
johnnyd
Hi All, will my 1998 TD5 have this EGR feature and should i blank it off if not already done ? Is there an easy way to tell if it has been dome or not, only had my Landy for 4 days Smile Is this OK to purchase ? http://www.ebay.co.uk/itm/Land-Rover-Defen...2a2ba963cd
Regards
JD
Post #227484 15th Apr 2013 4:43pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
you have PM fella.... Thumbs Up Putting Dreams on Drives at JLR Solihull..
Post #227653 15th Apr 2013 10:39pm
johnnyd
Thanks adafish.....I will look at the weekend.....the kit is relatively easy to fit I guess if I can work a spanner Smile
Post #227667 15th Apr 2013 10:55pm
johnnyd
BAH.......Stripped the 5mm Allen Nuts on the manifold Sad 2008 TDCi 2.4 XS CSW
Post #230895 27th Apr 2013 11:20am
johnnyd
I mean the inner head of the Allen bolt........ 2008 TDCi 2.4 XS CSW
Post #230903 27th Apr 2013 11:44am
mk1collector
Try some decent grips on them then renew when rebuilding Thumbs Up
Post #230912 27th Apr 2013 12:41pm
johnnyd
HELP......i am not sure where to put the second bung in IRB's EGR blanking kit, one i have placed over the blue pipe that came off the EGR valve, where doed the second one go, i have also removed the electrical cables off the only solenoid...
Thanks
JD 2008 TDCi 2.4 XS CSW
Post #232461 3rd May 2013 4:13pm
bob neville
Did it not come with any instructions ?
There are quite a few guides on the web showing you what to do - you have an EU2 engine.
2013 Defender 90 CSW - sold
Post #232468 3rd May 2013 4:40pm
johnnyd
Whats confusing me is the IRB kit is meant to come with a replacement servo hose to eradicate the T junction, mine hasn't got this servo replacement tube, so ATM i have removed the pipe from the t junction and placed the larger bung over that ?
It came with no instructions Sad
Post #232494 3rd May 2013 6:06pm
adafish
the little black bung goes on the airbox where the pipe went, you are right to but the IRB bung on the t piece bit...is that you on 0117 number earlier Putting Dreams on Drives at JLR Solihull..
Post #232498 3rd May 2013 6:29pm
johnnyd
Hi adafish, yes that was me earlier 0117......you sounded abroad ?
I don't have a pipe going to the airbox at all.......
Post #232503 3rd May 2013 6:57pm
adafish
i was...i'm in the states, a right state........give us a bell in morning fella. Putting Dreams on Drives at JLR Solihull..
Post #232562 3rd May 2013 10:32pm
