![]() | Home > Technical > TD5 EGR Blanking on 1998 TD5 |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Hi All, will my 1998 TD5 have this EGR feature and should i blank it off if not already done ? Is there an easy way to tell if it has been dome or not, only had my Landy for 4 days
![]() Regards JD |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
you have PM fella....
BAH.......Stripped the 5mm Allen Nuts on the manifold
I mean the inner head of the Allen bolt........ 2008 TDCi 2.4 XS CSW
Try some decent grips on them then renew when rebuilding
HELP......i am not sure where to put the second bung in IRB's EGR blanking kit, one i have placed over the blue pipe that came off the EGR valve, where doed the second one go, i have also removed the electrical cables off the only solenoid...
Thanks JD 2008 TDCi 2.4 XS CSW |
Did it not come with any instructions ?
There are quite a few guides on the web showing you what to do - you have an EU2 engine. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Whats confusing me is the IRB kit is meant to come with a replacement servo hose to eradicate the T junction, mine hasn't got this servo replacement tube, so ATM i have removed the pipe from the t junction and placed the larger bung over that ?
It came with no instructions ![]() JD 2008 TDCi 2.4 XS CSW |
the little black bung goes on the airbox where the pipe went, you are right to but the IRB bung on the t piece bit...is that you on 0117 number earlier Putting Dreams on Drives at JLR Solihull..
Hi adafish, yes that was me earlier 0117......you sounded abroad ?
I don't have a pipe going to the airbox at all....... JD 2008 TDCi 2.4 XS CSW |
i was...i'm in the states, a right state........give us a bell in morning fella. Putting Dreams on Drives at JLR Solihull..
