![]() | Home > Technical > 90 propshafts |
neddy Member Since: 03 Aug 2011 Location: Birmingham Posts: 61 ![]() ![]() |
How much longitudinal movement should there be? Both front and rear propshafts appear to be solid.
![]() Are they scrap? Proud owner of 1962 IIA since 1971, Talyllyn Railway enthusiast. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8325 ![]() ![]() ![]() |
10-20mm will cover most prop movements, my truck cab with a 2" lift and dislocation on the rear only have 15mm rear lateral movement. Cheers
You are correct about serious damage, see my son's posting "T’was the day before Christmas eve " in the Technical forum. The 90 "CEEDEE" is still off the road awaiting replacement transfer box etc.. Dave was cleaning the propshafts and we observed that there was no movement longitudinally even when addressed with a heavy adjusting tool. There was no evidence of grease anywhere but the UJs seem OK.
It looks as though, more expense for two propshafts. ![]() |
Gwyn Lewis if you need special ones get my vote. Cheers
