![]() | Home > Off Topic > Blackvue PC Software needed |
BarneyRubble Member Since: 08 Mar 2010 Location: Naphill Posts: 103 ![]() ![]() ![]() |
Don't know about the 300, but my 400 had the software loaded on the SD card. Barney
D4 - 2016 Graphite, Montalcino Red Written Off - 2010 90 Hard Top, Stornoway Grey |
Does the updated version not work with yours?
http://www.blackvue.com/en/contents/sub3.a...searchstr= ![]() |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Yea mine did too, but that was over 2 years ago and its been formatted several times since then! |
No, its for the HD version, tried that already. |
I thought that if you formatted the sd card, when you next put it in the blackview, it re-loaded all the software.
Must admit, I've never tried it. Barney D4 - 2016 Graphite, Montalcino Red Written Off - 2010 90 Hard Top, Stornoway Grey |
The firmware to operate the camera is located on the SD card. The PC software is used to set it up. Once you insert the SD card it works off those settings. I need the PC software to so it though!
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6702 ![]() ![]() ![]() |
Unless you've got an odd/clone BlackVue, BarneyRubble is right - if you put a blank SD card in a BlackVue then when it's powered up the camera will initialise the card and copy the viewer software etc to the SD card.
You do indeed carry out firmware updates via the SD card, but the actual firmware the camera uses is stored on the BV camera. I have a 300G and swap cards over without having to load anything onto each card first, and the software appears on the card after the initalisation ![]() Give it a try ![]() ![]() ![]() |
