Home > Off Topic > Blackvue PC Software needed
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I have a Blackvue DR300G camera in my Defender. I have recently changed my PC and cannot locate the software for the PC to view the videos on the SD card. I can find the Blackvue HD software for Windows, but not the basic version. Was wondering if anyone had it on their PC and could email it to me, or failing that a link if one exists?
Thanks
Steve
Post #222651 27th Mar 2013 7:00pm
BarneyRubble
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Don't know about the 300, but my 400 had the software loaded on the SD card. Barney
D4 - 2016 Graphite, Montalcino Red
Written Off - 2010 90 Hard Top, Stornoway Grey
Post #222654 27th Mar 2013 7:19pm
Laurie
Does the updated version not work with yours?
http://www.blackvue.com/en/contents/sub3.a...searchstr=
Post #222655 27th Mar 2013 7:20pm
borderterrier
Yea mine did too, but that was over 2 years ago and its been formatted several times since then!
Post #222656 27th Mar 2013 7:20pm
borderterrier
No, its for the HD version, tried that already.
Post #222657 27th Mar 2013 7:21pm
BarneyRubble
I thought that if you formatted the sd card, when you next put it in the blackview, it re-loaded all the software.
Must admit, I've never tried it. Barney
Post #222791 28th Mar 2013 9:18am
borderterrier
The firmware to operate the camera is located on the SD card. The PC software is used to set it up. Once you insert the SD card it works off those settings. I need the PC software to so it though!
Post #222807 28th Mar 2013 9:58am
Martin
Site Admin
Unless you've got an odd/clone BlackVue, BarneyRubble is right - if you put a blank SD card in a BlackVue then when it's powered up the camera will initialise the card and copy the viewer software etc to the SD card.
You do indeed carry out firmware updates via the SD card, but the actual firmware the camera uses is stored on the BV camera.
I have a 300G and swap cards over without having to load anything onto each card first, and the software appears on the card after the initalisation Smile
Give it a try Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #222817 28th Mar 2013 10:27am
