Home > Puma (Tdci) > heated rear screen
Baggie Austin
England 2009 Defender 90 Puma 2.4 HT Alpine White
heated rear screen
Apologies if its a silly question but do you not get a heated rear screen on the basic trim level defender?
Post #221204 22nd Mar 2013 6:15pm
Small Clanger
Post #221210 22nd Mar 2013 6:59pm
Baggie Austin
Small Clanger wrote:
Mine's a basic 90HT and has a heated rear screen.
As is mine mate, no button on the dash for it though. Confused
Post #221213 22nd Mar 2013 7:02pm
Small Clanger
On mine the switch is just to the left of the hazard light switch, have a look in my gallery, picture17.
Is yours blanked off?
Post #221220 22nd Mar 2013 7:23pm
Baggie Austin
Yeah its blanked off, but I have the wire feeding into the rear window. Strange
Post #221223 22nd Mar 2013 7:41pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Should be easy enough to wire a switch in then
Post #221261 22nd Mar 2013 9:58pm
Green Machine
Did you buy it new Austin? Chance that it was a 90 truck cab in a previous life? Does it have lashing hooks down the shoulder lines of the tub? (Usually a good giveaway). 2005 Td5 | 90 Station Wagon | Tonga Green
Post #221264 22nd Mar 2013 10:19pm
Baggie Austin
Not New, it's a 59 plate, How I got it yesterday. How do you mean hooks, sorry if I am being dumb.log book says hard top
Post #221271 22nd Mar 2013 11:00pm
Green Machine
No worries, it was just a thought. Sure it is a factory hard top. A truck cab (pick up) doesn't have a heated rear screen, so that switch is blanked off the dash. Truck cabs also have lashing hooks down the sides of the rear tub to attach a tonneau cover to. Often when they're converted to hard tops or station wagons people don't take the hooks off. It's a good way of telling that a vehicle has been converted rather than being a factory SW / HT. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #221276 22nd Mar 2013 11:16pm
Baggie Austin
It has the benches each side, puzzled as to why there is no switch. There appears to be a wire feeding what would be the heated screen.
Post #221280 22nd Mar 2013 11:27pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Have a look behind the blanking plate for the switch, it might have the wiring already installed for a switch.
Post #221282 22nd Mar 2013 11:31pm
You'll probably just need to pop a switch in. Even my 110 DC had all the wiring including relay and fuse for the HRW!
Post #221292 23rd Mar 2013 12:24am
Small Clanger
Final assembly of your Defender's dash was probably done by some lazy tw@ who'd run out of HRW switches and stuck a blank in instead. Rolling Eyes
The blanks are easy enough to ping out and, as mentioned, it's probable the necessary connector will be waiting.
Ask on here, someone will have a HRW switch kicking about.
Post #221304 23rd Mar 2013 7:55am
Baggie Austin
Cheers everyone, il pull the blank out and see whats happening behind it.
Post #221331 23rd Mar 2013 10:13am
Baggie Austin
Popped out the blanks, the one where the heated screen should be has all wires plugged in, so just need the switch im thinking then?
Post #221599 24th Mar 2013 1:59pm
