![]() | Home > Puma (Tdci) > heated rear screen |
Small Clanger Member Since: 22 Jun 2011 Location: UK Posts: 210 ![]() ![]() |
Baggie Austin Member Since: 16 Mar 2013 Location: Birmingham Posts: 102 ![]() ![]() ![]() |
As is mine mate, no button on the dash for it though. ![]() |
On mine the switch is just to the left of the hazard light switch, have a look in my gallery, picture17.
Is yours blanked off? |
Yeah its blanked off, but I have the wire feeding into the rear window. Strange |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Should be easy enough to wire a switch in then
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Did you buy it new Austin? Chance that it was a 90 truck cab in a previous life? Does it have lashing hooks down the shoulder lines of the tub? (Usually a good giveaway). 2005 Td5 | 90 Station Wagon | Tonga Green
Not New, it's a 59 plate, How I got it yesterday. How do you mean hooks, sorry if I am being dumb.log book says hard top |
No worries, it was just a thought. Sure it is a factory hard top. A truck cab (pick up) doesn't have a heated rear screen, so that switch is blanked off the dash. Truck cabs also have lashing hooks down the sides of the rear tub to attach a tonneau cover to. Often when they're converted to hard tops or station wagons people don't take the hooks off. It's a good way of telling that a vehicle has been converted rather than being a factory SW / HT. 2005 Td5 | 90 Station Wagon | Tonga Green
It has the benches each side, puzzled as to why there is no switch. There appears to be a wire feeding what would be the heated screen. |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 570 ![]() ![]() ![]() |
Have a look behind the blanking plate for the switch, it might have the wiring already installed for a switch.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
You'll probably just need to pop a switch in. Even my 110 DC had all the wiring including relay and fuse for the HRW!
Final assembly of your Defender's dash was probably done by some lazy tw@ who'd run out of HRW switches and stuck a blank in instead. ![]() The blanks are easy enough to ping out and, as mentioned, it's probable the necessary connector will be waiting. Ask on here, someone will have a HRW switch kicking about. |
Cheers everyone, il pull the blank out and see whats happening behind it.
Popped out the blanks, the one where the heated screen should be has all wires plugged in, so just need the switch im thinking then?
Cheers |
