![]() | Home > Puma (Tdci) > How do you change the air filter ? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8347 ![]() ![]() ![]() |
it hinges at the back in under the wing, lift it up a bit and then pull towards the engine bay, hinges will then 'unclip' and top will come off. Cheers
max peck Member Since: 30 Aug 2012 Location: Dubai Posts: 17 ![]() ![]() ![]() |
While on the topic...How about the air cleaner box?
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Thanks jst
![]() Just did it. Very very fiddly. Everything's in the way and you have to be extremely careful not to damage the paper element when you put it all back together. Its also hard to verify that the back lugs have engaged properly. You have to use a torch to see. No wonder there have been complaints about dealers not refitting the top properly. I think I'd rather do the gearbox oil - and there's not many who would agree with that ! Cheers |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Its easier to remove the pipe thus you can hinge up the top of the box Chris
2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
Yes I think I'll do that next time Dieselhead . I'm no mechanic and 'removing pipes' is a bit Ed China for me in the sense that I may not be able to reassemble it properly (like he would)
and how about the airbox dieselhead? How do you get it out? is there bolts underneath, i can see a couple of plastic thingys. or do i just force it up out rubber bungs like on the td5?
To be honest I dont know what holds the air box in place as I have never needed to remove a puma one
I am sure someone will advise us shortly ![]() Yes td5 is just rubber bungs Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
Pop rivets under the wheel arch that can be drilled to release the air box.
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
Do not put the filter in the box but hold it on the top so that you can engage the top correcly. I am sure it is not clear . Sorry PHIL current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
yes - and rather stupidly, the turret cover of the shock absorber has a self-tapping screw which is UNDER the air box...
If you ever fancy replacing the front shocks, it may be worth removing that screw whilst you are in there ![]() |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
I had a problem with the air filter on mine which got saturated by rain because the oafs employed by the stealer didn't put it back properly. I do it myself now and I unscrew the air pipe and move that out of the way, undo the clips and lift the front of the airbox lid up.
This makes taking the filter out easy and the lid comes out as well. To reinstall, fit filter into airbox top and keeping the nearest part to the engine tilted back towards you slip the part closest to you under the wing and push gently back. To get the filter to sit nicely in position gently try to close the lid by pushing the felt/paper parts of the filter back towards you and it will suddenly drop into position. Refix clips. The rear of the box lid should now be under the clips but it's sometimes still not a good fit but that seems to be it with the Puma....... AlanH. |
