Home > Puma (Tdci) > How do you change the air filter ?
rossy
This is embarrassing.
I've just spent the morning changing Gbox, Tbox, diff oils and greasing the props and I thought I'd change the air filter too. Looks easy. Just release the two clips and give it a wiggle I thought. But I wiggled and wiggled and the top of the airbox stayed stuck at the back where its tucked under the wing. I have done a search and there's nothing on how to change it. Is it really that easy and am I just thick because no ones had to ask before ? Laughing Please tell me how. Ta
Post #220641 20th Mar 2013 3:29pm
jst
it hinges at the back in under the wing, lift it up a bit and then pull towards the engine bay, hinges will then 'unclip' and top will come off. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #220647 20th Mar 2013 4:00pm
max peck
United Arab Emirates 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
While on the topic...How about the air cleaner box?
Post #220653 20th Mar 2013 4:58pm
rossy
Thanks jst Thumbs Up
Just did it. Very very fiddly. Everything's in the way and you have to be extremely careful not to damage the paper element when you put it all back together. Its also hard to verify that the back lugs have engaged properly. You have to use a torch to see. No wonder there have been complaints about dealers not refitting the top properly.
I think I'd rather do the gearbox oil - and there's not many who would agree with that ! Cheers
Post #220666 20th Mar 2013 6:07pm
Dieselhead
Its easier to remove the pipe thus you can hinge up the top of the box Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #220667 20th Mar 2013 6:08pm
rossy
Yes I think I'll do that next time Dieselhead . I'm no mechanic and 'removing pipes' is a bit Ed China for me in the sense that I may not be able to reassemble it properly (like he would) Embarassed
Post #220673 20th Mar 2013 6:51pm
max peck
and how about the airbox dieselhead? How do you get it out? is there bolts underneath, i can see a couple of plastic thingys. or do i just force it up out rubber bungs like on the td5?
Post #220719 20th Mar 2013 8:16pm
Dieselhead
To be honest I dont know what holds the air box in place as I have never needed to remove a puma one
I am sure someone will advise us shortly Thumbs Up
Yes td5 is just rubber bungs Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #220734 20th Mar 2013 8:43pm
mermoto
Pop rivets under the wheel arch that can be drilled to release the air box.
Post #221046 22nd Mar 2013 12:46am
mermoto
Post #221047 22nd Mar 2013 12:46am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Do not put the filter in the box but hold it on the top so that you can engage the top correcly.
I am sure it is not clear .
Sorry
PHIL current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #269874 28th Sep 2013 6:35am
MartinK
yes - and rather stupidly, the turret cover of the shock absorber has a self-tapping screw which is UNDER the air box...
If you ever fancy replacing the front shocks, it may be worth removing that screw whilst you are in there Thumbs Up [/i] Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #269875 28th Sep 2013 7:09am
AlanH
Australia
I had a problem with the air filter on mine which got saturated by rain because the oafs employed by the stealer didn't put it back properly. I do it myself now and I unscrew the air pipe and move that out of the way, undo the clips and lift the front of the airbox lid up.
This makes taking the filter out easy and the lid comes out as well.
To reinstall, fit filter into airbox top and keeping the nearest part to the engine tilted back towards you slip the part closest to you under the wing and push gently back.
To get the filter to sit nicely in position gently try to close the lid by pushing the felt/paper parts of the filter back towards you and it will suddenly drop into position. Refix clips.
The rear of the box lid should now be under the clips but it's sometimes still not a good fit but that seems to be it with the Puma.......
AlanH.
Post #269890 28th Sep 2013 9:30am
