![]() | Home > For Sale & Wanted > WANTED: Tubular Bumperettes For Defender |
I can highly recommend them. I've had a set fitted to mine for over four years and recently had the brackets ground off, new ones made and rewelded in a different place so I can fit it with a Safari swing away wheel carrier. The old welds were ground down, polished up and the bumperette came up like new. You get what you pay for and I bought the Bearmach ones from the link below. There are significantly cheaper ones available but as ever the choice is yours.....
![]() http://www.rimmerbros.co.uk/Item--i-LL1212...tAodtjQA6Q ![]() Treat every day as if it is your last....one day you will be right!! |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2277 ![]() ![]() |
Hi why don't you have your own made ? Pop down your local welder , give him a cardboard template of your brackets cut out to your own shape using the correct chassis holes . Have them cut to your own dimensions and welded onto 4 inch diameter 6mm pipe cut to your own correct length . Galvanise and finish with black hammerite with a nice piece of checker plate on top . Never mind the cheep nasty company efforts rusting and so called heavy duty that don't fit the chassis holes correct . |
Lump o Lard Member Since: 21 Jan 2013 Location: East Anglia Posts: 12 ![]() ![]() ![]() |
Appreciate the replies guys but I really do want to get a used pair if poss.
Cant see the point of making or buying new if I can do a tiny bit of "green" good! Lardy. Give me a break I'm new to this! |
I haven't seen many Landies with the tubular variety fitted, I also think that they are more or less a 'fit and forget' item especially on the Puma as unless you use rivnuts they can be a complete b45t4rd to fit.
Hope you get what you seek but rare as hen's teeth born by the fact there has only ever been one square one featured in the For Sale & Wanted topic. Good luck with your quest...... ![]() Treat every day as if it is your last....one day you will be right!! |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627 ![]() ![]() ![]() |
I've got some I've recently taken off. Let me take a few photos.
It would appear we have a poultry dentist in the house!
It certainly does! We can add it to the list of a 'spectacle maker and horse dentist!' It just advocates the adage "If you don't ask, you don't get!"
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
Lardy - if it helps I have a pair from killer90's old white 90 (i'm sure you'll find a photo somewhere - single tubular job - sorry cant help more at moment tied up).
if interested let me know and I'll sort some photos etc. |
