Home > For Sale & Wanted > WANTED: Tubular Bumperettes For Defender
Lump o Lard
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Hi All,
I am after a set of tubular rear bumperettes for a defender.
I know they can be had on various online sellers websites but I would rather "recycle" a used pair if anyone has some!
Many thanks in advance.
Lardy. Give me a break I'm new to this!
Post #215687 3rd Mar 2013 9:21am
K9F
I can highly recommend them. I've had a set fitted to mine for over four years and recently had the brackets ground off, new ones made and rewelded in a different place so I can fit it with a Safari swing away wheel carrier. The old welds were ground down, polished up and the bumperette came up like new. You get what you pay for and I bought the Bearmach ones from the link below. There are significantly cheaper ones available but as ever the choice is yours.....
Thumbs Up
http://www.rimmerbros.co.uk/Item--i-LL1212...tAodtjQA6Q
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #215693 3rd Mar 2013 10:11am
keith
Re: WANTED: Tubular Bumperettes For Defender
Lump o Lard wrote:
Hi All,
Lardy.
Hi why don't you have your own made ? Pop down your local welder , give him a cardboard template of your brackets cut out to your own shape using the correct chassis holes . Have them cut to your own dimensions and welded onto 4 inch diameter 6mm pipe cut to your own correct length . Galvanise and finish with black hammerite with a nice piece of checker plate on top . Never mind the cheep nasty company efforts rusting and so called heavy duty that don't fit the chassis holes correct .
Post #215695 3rd Mar 2013 10:36am
Lump o Lard
Appreciate the replies guys but I really do want to get a used pair if poss.
Cant see the point of making or buying new if I can do a tiny bit of "green" good!
Post #215707 3rd Mar 2013 11:30am
K9F
I haven't seen many Landies with the tubular variety fitted, I also think that they are more or less a 'fit and forget' item especially on the Puma as unless you use rivnuts they can be a complete b45t4rd to fit.
Hope you get what you seek but rare as hen's teeth born by the fact there has only ever been one square one featured in the For Sale & Wanted topic.
Good luck with your quest...... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #215711 3rd Mar 2013 11:41am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I've got some I've recently taken off. Let me take a few photos.
Post #215846 3rd Mar 2013 6:57pm
Lump o Lard
It would appear we have a poultry dentist in the house!
Post #215883 3rd Mar 2013 8:29pm
K9F
It certainly does! We can add it to the list of a 'spectacle maker and horse dentist!' It just advocates the adage "If you don't ask, you don't get!"
Alive Tuning wrote:
James is quite an accomplished Equine Dental Technician (Horse dentist), .
steve E wrote:
The funny thing about those rose tinted glasses is I'm a spectacle maker by trade so could do a group discount for the forum members Whistle
Post #215887 3rd Mar 2013 8:35pm
Caterham
Lardy - if it helps I have a pair from killer90's old white 90 (i'm sure you'll find a photo somewhere - single tubular job - sorry cant help more at moment tied up).
if interested let me know and I'll sort some photos etc.
Post #216015 4th Mar 2013 10:30am
