![]() | Home > Td5 > Problem with my 02 td5 |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2519 ![]() ![]() |
Hi there all!
I'm after a bit of advice if I may! My td5 has started to clatter on start up when cold, then there's a slow whooring sound up and down, What could it be? Flywheel? Also if I accelerate briskly to 50-60 it cuts power for a second or two then the engine light comes on then drives normally? Til I turn off n restart then light goes out? Any knowledgable td5 persons able to guess what it could be? Many thanks Kenny 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Is the whine when you dip the clutch on first start up Ken
![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
Steve that would be for which problem or is it suggestions for both? 2011 Santorini Black USW XS.
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
I don't think you will get the engine light come on if the wastegate is sticking (mine never did anyway), and it won't drive normally after a second or two. If the waste gate is sticking it will feel like your hitting a governor and you will get some surging at around 60mph. With the wastegate not opening, the turbo will be overboosting. The ECU will detect this and cut the fuel. As the boost drops, fueling will then increase and the whole process starts again, leading to surging.
It could be old oil in the ecu, ill have to clean that out tomorrow, see if that makes a difference as i have been cleaning it out every 2 weeks for last 2 months but i forgot about it til now!
Its going in the garage next week to have these faults and broken door locks fixed anyway ![]() 2015 Discovery 4.5 Black pack Firenze red XS |
