Home > Td5 > Problem with my 02 td5
Welshsurferdude
Wales
Hi there all!
I'm after a bit of advice if I may!
My td5 has started to clatter on start up when cold, then there's a slow whooring sound up and down,
What could it be? Flywheel?
Also if I accelerate briskly to 50-60 it cuts power for a second or two then the engine light comes on then drives normally? Til I turn off n restart then light goes out?
Any knowledgable td5 persons able to guess what it could be?
Many thanks
Kenny 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #213791 24th Feb 2013 1:42pm
Killer90
Site Sponsor
Is the whine when you dip the clutch on first start up Ken Question CSK Automotive
www.cskautomotive.co.uk
Post #213800 24th Feb 2013 2:15pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
I don't think so killer, I know the noise your thinking of.
Sounds like 2 separate problems to me.
Open the bonnet and check your viscous fan isn't failing, also check your watergate isn't stuck. IRB Developments have a helpful video here.
&feature=plcp
Post #213818 24th Feb 2013 3:14pm
Welshsurferdude
Wales
Steve that would be for which problem or is it suggestions for both? 2008 Santorini Black 110 XS USW (Sold)
Post #213885 24th Feb 2013 6:52pm
Steve B
Sorry,
Clattering sound for the viscous fan, this is just a guess.
And the sticky waste gate for the power cut 50-60 as this might be when the ecu senses an overboost. The waste gate does as it says opens a gate to waste any excess boost, except when it sticks. It's quite stiff but will move freely not stuck or notchy.
Post #213920 24th Feb 2013 7:44pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
I don't think you will get the engine light come on if the wastegate is sticking (mine never did anyway), and it won't drive normally after a second or two. If the waste gate is sticking it will feel like your hitting a governor and you will get some surging at around 60mph. With the wastegate not opening, the turbo will be overboosting. The ECU will detect this and cut the fuel. As the boost drops, fueling will then increase and the whole process starts again, leading to surging.
Post #213988 24th Feb 2013 9:30pm
Steve B
Sounds like you need to read the faults, you will have a much better idea then.
One mains surging is another mans loss of power?
True about the light, when my waste gate was sticky no light came on. Possibly the old oil in the ecu plug?
Post #214023 24th Feb 2013 10:57pm
Welshsurferdude
Wales
It could be old oil in the ecu, ill have to clean that out tomorrow, see if that makes a difference as i have been cleaning it out every 2 weeks for last 2 months but i forgot about it til now!
Its going in the garage next week to have these faults and broken door locks fixed anyway Smile 2008 Santorini Black 110 XS USW (Sold)
Post #214048 24th Feb 2013 11:38pm
