Home > Technical > Rear wiring loom
Likeomg
Rear wiring loom
if i wanted to take a 12v supply out of the loom, to power something that requires very low power, is it possible? if so, which cables / does anyone have a to hand copy of the rear loom?
Post #211101 14th Feb 2013 1:18am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
I think there is a fused 12v supply behind the speaker cover in the rear tub - no idea of wire colours as I'm at work at the mo (hence being online at 0300hrs!) and so can't get to the wiring diagram. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #211107 14th Feb 2013 4:14am
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I recall someone here mention a purple wire (or purple + white) at the rear door that is a permanent live. Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #211108 14th Feb 2013 5:11am
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
If it is pre 2012 you should have a live feed behind the speaker in the back. I have a 2012 110 and it does not have that wire any more.
If you put a search in you will come back with something like this.
Looking at the MY12 circuit diagrams and electrical library, the 2-way 6.3mm 'T' connector , with live and earth in it, seems to have been deleted from the build.
The towing pick up connector C0929 has a permanent fused live in it, but this can difficult to connect to, unless you have the towing electrics kit. 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #211109 14th Feb 2013 5:53am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
As you drive a 2010 car it should be there behind the speaker.
Post #211113 14th Feb 2013 8:05am
excossack
There is a purple wire in the rear drivers side of my 110 1999 td5 behind the panel. Mine had a female spade connector already attached 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #211132 14th Feb 2013 10:12am
