![]() | Home > Technical > Rear wiring loom |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2668 ![]() ![]() |
if i wanted to take a 12v supply out of the loom, to power something that requires very low power, is it possible? if so, which cables / does anyone have a to hand copy of the rear loom?
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
I think there is a fused 12v supply behind the speaker cover in the rear tub - no idea of wire colours as I'm at work at the mo (hence being online at 0300hrs!) and so can't get to the wiring diagram. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
jayaway44 Member Since: 04 Nov 2011 Location: Edinburgh Posts: 111 ![]() ![]() |
If it is pre 2012 you should have a live feed behind the speaker in the back. I have a 2012 110 and it does not have that wire any more.
If you put a search in you will come back with something like this. Looking at the MY12 circuit diagrams and electrical library, the 2-way 6.3mm 'T' connector , with live and earth in it, seems to have been deleted from the build. The towing pick up connector C0929 has a permanent fused live in it, but this can difficult to connect to, unless you have the towing electrics kit. 2.2 2012 110 utility Orkney Grey Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
As you drive a 2010 car it should be there behind the speaker.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6015 ![]() ![]() ![]() |
There is a purple wire in the rear drivers side of my 110 1999 td5 behind the panel. Mine had a female spade connector already attached 1999 Defender TD5 110
