Home > Maintenance & Modifications > Replacement brake pipes
excossack
On the MOT the tester advised on corrosion to brake pipes at the front and the rear.
Maybe time to replace the pipes, so what type of pipe is suggested?
I have seen Copper, Nickel or can you get stainless pipe?
At the same time I will replace the flexis with stainless/braided ones which I got a while ago.
If doing myself, I would have to invest in the tools to cut/flare the brake pipes. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #210828 12th Feb 2013 10:32pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
On my 300 I replaced the pipes using a kit from Automec. All cut to size and all connectors attached. Was much easier thank I thought it would be.
http://www.rimmerbros.co.uk/Item--i-GRID010541 BM52
Post #210830 12th Feb 2013 10:36pm
Lou Sparts
Order the pipes from your main dealer they will come already shaped for an easy fit. 2005 Td5 90 XS
Steve
Post #210835 12th Feb 2013 10:48pm
excossack
That's a good thought, I might just give them a buzz. 1999 Defender TD5 110
Regards
John M0VAZ
Post #210837 12th Feb 2013 10:54pm
MartinK
Or you can put copper brake lines on....they'll last much longer
Some on ebay, and Rimmer do a full ready-made kit here
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #210840 12th Feb 2013 11:02pm
jst
i would make my own using a flare kit.
or run braided flex from the calipers to a bulkhead join or even straight to the mc. depends what your using the vehicle for. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #210867 13th Feb 2013 7:54am
excossack
Ordered from Automec today. Full hit, both pipes on rear axle, pipes for the front and the one that runs down the chassis rail (front/back) 1999 Defender TD5 110
Regards
John M0VAZ
Post #239472 29th May 2013 1:30pm
bm52
can I suggest you soak the flex pipe joints from the chassis to the T connection on the rear axle with loads of WD40 or similar. Mine was a right sod to remove and undo Twisted Evil , gave up in the end and bought a new flex pipe and T connector. BM52
Post #239490 29th May 2013 4:33pm
excossack
I've got new flexis to go on, braided ones Smile but a good soaking will be in order with Plusgas etc. 1999 Defender TD5 110
Regards
John M0VAZ
Post #239491 29th May 2013 4:39pm
bm52
Just to be clear i was referring to the chassis to T connection and not the one to the calipers.
A grinder became my friend on this job BM52
Post #239492 29th May 2013 4:44pm
excossack
I hope I dont have to break out the grinder! 1999 Defender TD5 110
Regards
John M0VAZ
Post #239500 29th May 2013 5:51pm
