![]() | Home > Maintenance & Modifications > Replacement brake pipes |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
On my 300 I replaced the pipes using a kit from Automec. All cut to size and all connectors attached. Was much easier thank I thought it would be.
http://www.rimmerbros.co.uk/Item--i-GRID010541 BM52 |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Order the pipes from your main dealer they will come already shaped for an easy fit. 2005 Td5 90 XS
Steve |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
That's a good thought, I might just give them a buzz. 1999 Defender TD5 110
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Or you can put copper brake lines on....they'll last much longer
Some on ebay, and Rimmer do a full ready-made kit here http://www.rimmerbros.co.uk/Item--i-GRID010541 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8489
i would make my own using a flare kit.
or run braided flex from the calipers to a bulkhead join or even straight to the mc. depends what your using the vehicle for. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Ordered from Automec today. Full hit, both pipes on rear axle, pipes for the front and the one that runs down the chassis rail (front/back) 1999 Defender TD5 110
can I suggest you soak the flex pipe joints from the chassis to the T connection on the rear axle with loads of WD40 or similar. Mine was a right sod to remove and undo
I've got new flexis to go on, braided ones
Just to be clear i was referring to the chassis to T connection and not the one to the calipers.
A grinder became my friend on this job BM52 |
I hope I dont have to break out the grinder! 1999 Defender TD5 110
| All times are GMT |
