Home > Maintenance & Modifications > Chequer Plate - keeping it neat!
otter-spotter
Just joined the forum after pretty much reading everything on here! Thought I would try to put something back. Hope this works...
I have had my 2012 110 USW for about 2 months and already noticed corrosion around dealer fitted screws that secure chequer plate to wings. Easy fix was to replace them with A2 stainless M6 x 20 countersunk screws from screwfix and a LOT of copper slip. Probably easier than getting the dealer to change them every 6 months! They fix straight in to existing rivnets - hopefully no problems between those metal types? (probably no worse than it was...)
Post #210684 12th Feb 2013 12:19pm
ZeDefender
If you've got black (or other coloured plate), you can also use these:
http://www.gwr-fasteners.co.uk/m6-counters...1357-p.asp
Despite the difference in anodic index, ss and alu aren't too bad together, especially with Copperslip, Duralac etc.
Smile Tell someone you love them today because life is short.
Post #210704 12th Feb 2013 1:48pm
