![]() | Home > Td5 > Stay with Auto or change back to manual gearbox? |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
No they were fitted to nearly all 110s prior to the early 1990s including the utility V8s (not sure about CSW V8s). I think it was only with the arrival of the TDi that that changed. It might have even been the same for the 200TDi, not sure without doing some digging. For many years the 110 got the 1.6 as standard and the 90 got the 1.4, the 90 had smaller tyres (factory fit) and was lighter so they could pull the 1.4. http://www.yorkshireoffroadclub.net/
i got a 1.6 that needs a rebuild here.
you can pul away in low range and snick it into high range with some practice |
You could probably fit an overdrive... very spendy though and not sure what, if any, types are still available. GKN used to do one, not sure if it's still available. Mr Ashcroft is your man for that
![]() The 1.6 box on it's own will just drop all the "high range" ratios, the low range ratio is the same as your current low range. http://www.yorkshireoffroadclub.net/ |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 ![]() |
Thanks for your help mate.
I'll probably give Mr Ashcroft a ring about a 1.6 box, as I have had bad experiences with second hand t/box and gearboxes. As the truck is used for work nearly every day it needs to be reliable. Certainly sounds like a 1.6 box would solve my problem of revving hard to get anywhere at low speed. As soon as I get onto anything soft I have to use low ratio. 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
joelyates18 Member Since: 22 Dec 2012 Location: Neath Posts: 39 ![]() ![]() ![]() |
Personally I'm not a fan of automatics I mean sure they have their place but I enjoy driving and it's a lot more involving of a drive with a manual so it really is up to personal choice at the end of the day only you can answer your question
![]() Happy Roving! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
if an auto is sluggish pulling away then the TC is slipping, make sure it has a good cooler to combat this. (or two) what temp does she run at? if you change to manual then you will be slipping a clutch to achieve the same affect unless you change the gearing.
1.6 box as mentioned change to 4.11 Diffs? fit smaller OD wheels underdrive? use Low to pull away low is the same in all T boxes. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
1.6 transfer box turned up from Ashcroft. In the process of getting it and can't get it in the last 1/2 inch. Checked if a collar was left in the back of the autobiography and it isn't.
I've got the correct output shaft on the back of the auto box so puzzled. Tried pulling it together with the bolts but they go too tight without anything moving. Any ideas anyone please? 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
Check you don't have locating pegs on both halves !
I've also had instances where the locating pegs or too tight a fit to go into one half or the other due to corrosion, factory tolerances etc... http://www.yorkshireoffroadclub.net/ |
Doh! Can't believe I did that. You were right it was the tiny dowel in both halves causing the problem. Luckily I could one out by moving the box back a bit - phew! Another quick question - on the front there is a red hole plug like the one for the breather on top. I don't have anything to put in this what is it for? 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
High-low switch maybe ? A pic would help... http://www.yorkshireoffroadclub.net/
Hi Dave There is a pic on the low range - lack of response thread, Dave is pointing at it! It is to do with the throttle response and been suggested to remove it. What is best to plug the hole with, just leave the red plug in there? Cheers.... Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
Personally I'd stick a high-low switch in there even if you don't connect it for the moment. As discussed on the thread, it's pretty much only there so the ECM can adapt the throttle response when in low box.
Alternatively it's bound to be a standard thread so getting a suitable plug for it shouldn't be a problem if you can find out the thread - I'm sure Ashcrofts will be able to help. As a purely temporary fix... you'll probably be fine with the red plug in there, maybe add some duct tape or similar to make sure it doesn't vibrate out. Keep an eye on it though and don't go wading ! ![]() |
