Home > Technical > EGR about to go but what then?
AndyS
2011, 110 2.4 and today it's not running so good and the ERG valve is making a right old racket. It must be the ERG as it squeaks loudly when I switch the engine off for its five cleaning cycles but it also squeaks at low engine speeds, at junctions and that type of thing, I'm guessing that's the ERG working it's magic? It's a similar sound to suspension squeaks but it's not that.
However, it's under warranty so it's their problem but what happens when the EGR fails? Would it cause any other damage or would it just be a slightly worse running engine and worse economy? Is it something I could put off for a while? Should I unplug it in the mean time?
Thanks people.
Post #208016 3rd Feb 2013 5:27pm
Won't cause any damage under certain circumstances. Cures are either to replace for a new one or a re-map to disable it. As it's under warranty take it to the dealer and get it sorted there it shouldn't be playing up already as it's so new mine lasted 5 years before packing up last year. My guess is they'll replace it. Also if you have the MIL light illuminated on the dash it will fail an MOT for that now. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #208018 3rd Feb 2013 5:30pm
ZeDefender
Steve, am I right that remap will only work if the valve's closed to start with? If the valve's dying and may get stuck open, better to pull the plug whilst it's closed and put up with the MIL until the cavalry (e.g. BAS or Alive) arrive... Tell someone you love them today because life is short.
Post #208025 3rd Feb 2013 5:47pm
Yes that is true but depends on situation. Best course of action if you ask me is to get it replaced at the dealer being so new. Once replaced if he chose to it could then be closed and disabled. ____\We|Will|Win/___
Post #208027 3rd Feb 2013 5:56pm
ericvv
My EGR packed up when the truck was 6 months old. The MIL light went on and the car went in limp mode. Happened several times within a few days, so took it back to the dealer, and they replaced it under warranty. Has been running perfect ever since (that is now more than 4 years). As your truck is under warranty, get LR to solve it, which obviously will be by replacing it, as a remap to keep the EGR closed is not in their handbook, and actually I think would compromise your further warranty rights.
One thing I have clearly noticed was that as long as I was running local supermarket diesel (first 2 years), the EGR cleaning cycle was a bit noisy, even if it worked fine, but I think it must be a good 2 years now that I switched to using premium fuels only, almost exclusively BP Ultimate that is. Once I did that, the cleaning cycle completely changed tone, much gentler now, any roughness in the sound of that cleaning cycle is entirely gone.
Good luck with LR, and keep your warranty uncompromised Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #208031 3rd Feb 2013 6:06pm
AndyS
Thanks for the replies.
I will definitely get it replaced but wondered if it's a get it to the dealer while it's still running problem or something I could put off until I'm next off work. I'm glad I can put it off as I only started a new job on Thursday, bit soon to be getting days off for breakdowns. Laughing
I quite like the idea of a re-map but also like the fact I can put any old crap in it and it'll run happily. It seems re-maps do away with that 'feature'.
Post #208033 3rd Feb 2013 6:06pm
ZeDefender
As eric says, don't compromise your warranty Thumbs Up
Bear in mind though that the portable remap interfaces that many on here (including me) use, allow you to revert to the original software whenever you want (untraceable by LR).
Secondly, you can use sh*t diesel in a standard or remapped Defender - it just makes both of them run like sh*t Laughing Tell someone you love them today because life is short.
Post #208037 3rd Feb 2013 6:16pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi AndyS, I'm not an expert on remapping but I think you are incorrect in your statement regarding remaps and fuel quality. A Defender with a remap can still cope with a wide range of fuel qualities as proved by some of the South African members on this forum. Certainly it can cope with anything found in the " Western World".
Post #208040 3rd Feb 2013 6:22pm
ericvv
Should have said additionally in my post that since I switched to premium fuels, not only the EGR cleaning cycle became much more gentle, but the engine overall is running much quieter. With the supermarket fuels there was a blacksmith hammering away somewhere under the bonnet, with BP Ultimate that guy apparently went for retirement Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #208042 3rd Feb 2013 6:26pm
Just for a bit off added extra info:
Post #208100 3rd Feb 2013 8:31pm
bell-auto-services
Glad someone else agree's that supermarket fuel is Censored Thumbs Up
Post #208101 3rd Feb 2013 8:33pm
rossy
Andy I know its been said a thousand times here but when you get your new EGR a good squirt of 2-stroke oil when re fuelling helps to keep it clean. My '11 Puma is mostly used for frequent very short journeys and the self clean cycle sounds more like 5 barely audible 'shukas' - not even chukas (the forum standard sound of the cleaning cycle). I assume the smoother the chukas the less gunged up the EGR - from what I've read here anyway !
Post #208174 4th Feb 2013 12:32am
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
I would never use supermarket fuel quickest way to feck your injectors up Shocked
Just had my Egr changed under warranty but I was told that some garages won't change them unless it shows a fault up on the computer which I found out when Guy salmon wakefield refused to change it even though it was making a racket and you could here it working
When I got it changed at another dealer they said it was stuck half way Thumbs Up
Post #208372 4th Feb 2013 8:07pm
