Home > Maintenance & Modifications > Defender Drawer System
Naks
Morning all,
We've had a 'standard' drawer system in the landy for a few years now, but I am not happy with the fridge being on top of the drawers.
The obvious solution is to remove one side of the drawer and bring the fridge down to the load-bay level (by the rear door hinge).
Has anyone done this? Pros/cons?
Thanks! --
Post #206211 28th Jan 2013 11:57am
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
I spend some time looking at rear storage fridges draws etc and came to the conclusion that the draw would not suit my needs so I ended up building my own. It works really well and massively increases the storage and ease of use. I took a lot of inspiration from here (http://www.expeditionportal.com/forum/threads/9034-Post-up-your-drawer-storage-system)
I did create a build thread for the project here (http://forums.lr4x4.com/index.php?showtopic=71292&page=1)
Jason.
Post #206229 28th Jan 2013 1:59pm
Naks
Jason.
Wow, thanks Jason, that looks very similar to what I had in mind:
Post #206230 28th Jan 2013 2:03pm
jasong4110
The two things you need to consider is the back door and back door catch, if you look at mine the fridge is slightly offset to clear the door catch, and on the right I have wolf boxes on the Right.
If you access my build thread you will note that I made my unit 8cm higher than it needed to be to clear the fridge but this then put it level with the dog guard which allowed me to build a sleeping platform.
Jason.
Post #206231 28th Jan 2013 2:12pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Thumbs Up Thumbs Up looks great It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #206260 28th Jan 2013 4:27pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
That looks great, bet there's a market for that. Thumbs Up How do you get into the space above the wheel arches?
Post #206284 28th Jan 2013 7:21pm
jasong4110
the wheel arch 'bins' are covered with two removable boards these just lift and slide out of the way giving you access to them.
Jason.
Post #206289 28th Jan 2013 7:27pm
@jasong, that looks a job well done Thumbs Up
Where did you get the netting/webbing, I need a big one of the to use on mr roof rack and in the back ?
Post #206314 28th Jan 2013 8:19pm
jasong4110
I made it, I brought two 50m rolls of seat belt webbing similar to this http://www.ebay.co.uk/itm/50mm-2-inch-roll...460c3731e9 and made nets for the front and back.
Jason.
Post #206322 28th Jan 2013 8:36pm
yobbie
Where did you get the runners for the fridge shelf?
Post #206386 28th Jan 2013 9:56pm
jasong4110
B&Q
Post #206412 28th Jan 2013 10:40pm
Naks
After looking around various setups, I think I've found something that could work, based on the following design:
Instead of the window boxes, we will have a row of ammo boxes on each side, accessible via gullwing doors.
There will be 2 load bins between the window sill and wheelarches. I can fit all big recovery kit in one and camping chairs/tent/mats in the other.
The camping table will go in a horizontal slot in the middle on top of the fridge/drawer combo. On top of that we can stuff pillows, and other big+light items, secure by a net.
Can anyone spot any obvious shortcomings? Smile --
Post #206512 29th Jan 2013 12:03pm
Naks
While on the subject of maximising the space I can use inside the landy, what is the best way to go about increasing the clearance when opening the rear door on a Defender?
After-market wheel carrier? If so, which one?
For example, in my previous post above, it seems to me that the rear door on that landy can open far wider than mine does - I do not see a strut like on mine? --
Post #206757 30th Jan 2013 10:28am
jasong4110
As you may have read that photo was my inspiration.
By 'Ammo boxes' do you mean plastic Wolf type boxes or metal ammo boxes?
What do you mean by gullwing doors? Are they the doors that replace the windows?
I made a high level shelf in mine it was really simple to make and picked up on the window guard brackets:
I use that for lightweight bits like coats, pillows and sleeping bags, as you want to store heavy things as low as possible.
Jason.
Post #206760 30th Jan 2013 10:41am
jasong4110
Yes to open the door further you need a spare wheel carrier this offsets the opening and helps it open that couple of inches more, the Mantec carrier will give you more room.
Jason.
Post #206763 30th Jan 2013 10:46am
