![]() | Home > Maintenance & Modifications > Defender Drawer System |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Morning all,
We've had a 'standard' drawer system in the landy for a few years now, but I am not happy with the fridge being on top of the drawers. The obvious solution is to remove one side of the drawer and bring the fridge down to the load-bay level (by the rear door hinge). Has anyone done this? Pros/cons? Thanks! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Wow, thanks Jason, that looks very similar to what I had in mind: ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 ![]() ![]() ![]() |
The two things you need to consider is the back door and back door catch, if you look at mine the fridge is slightly offset to clear the door catch, and on the right I have wolf boxes on the Right.
![]() If you access my build thread you will note that I made my unit 8cm higher than it needed to be to clear the fridge but this then put it level with the dog guard which allowed me to build a sleeping platform. Jason. |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
![]() ![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
That looks great, bet there's a market for that.
the wheel arch 'bins' are covered with two removable boards these just lift and slide out of the way giving you access to them. Jason. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
@jasong, that looks a job well done
![]() Where did you get the netting/webbing, I need a big one of the to use on mr roof rack and in the back ? |
I made it, I brought two 50m rolls of seat belt webbing similar to this http://www.ebay.co.uk/itm/50mm-2-inch-roll...460c3731e9 and made nets for the front and back. Jason. |
Where did you get the runners for the fridge shelf?
B&Q |
After looking around various setups, I think I've found something that could work, based on the following design:
![]() Instead of the window boxes, we will have a row of ammo boxes on each side, accessible via gullwing doors. There will be 2 load bins between the window sill and wheelarches. I can fit all big recovery kit in one and camping chairs/tent/mats in the other. The camping table will go in a horizontal slot in the middle on top of the fridge/drawer combo. On top of that we can stuff pillows, and other big+light items, secure by a net. Can anyone spot any obvious shortcomings? ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
While on the subject of maximising the space I can use inside the landy, what is the best way to go about increasing the clearance when opening the rear door on a Defender?
After-market wheel carrier? If so, which one? For example, in my previous post above, it seems to me that the rear door on that landy can open far wider than mine does - I do not see a strut like on mine? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
As you may have read that photo was my inspiration. By 'Ammo boxes' do you mean plastic Wolf type boxes or metal ammo boxes? What do you mean by gullwing doors? Are they the doors that replace the windows? I made a high level shelf in mine it was really simple to make and picked up on the window guard brackets: ![]() I use that for lightweight bits like coats, pillows and sleeping bags, as you want to store heavy things as low as possible. Jason. |
Yes to open the door further you need a spare wheel carrier this offsets the opening and helps it open that couple of inches more, the Mantec carrier will give you more room. Jason. |
