Home > Maintenance & Modifications > turbo boost puma
Tim seymour
Australia
turbo boost puma
Hi can anyone tell me the standard boost for puma mine is running a remap at the momment and it put out a code 234 overboost about 20 psi spike cheers Tim Cess the Taswegian
Post #203781 21st Jan 2013 8:40am
Defender-Stu
Wow that's 1.6 bar and a little high if I'm right as the std boost is about 0.7 bar but could be wrong?
Post #203788 21st Jan 2013 9:29am
Tim seymour
Australia
1.3 bar i thought 18 psi was the go cheers Tim Cess the Taswegian
Post #203791 21st Jan 2013 9:53am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Mine also have a remap/intercooler/de-cat and my max Boost PSI that I could get was 19PSI.
No error codes though......
Post #203823 21st Jan 2013 1:20pm
Lorryman100
33 -34 psi, 232KPA with a remap and standard intercooler. Thumbs Up
Another factor to consider is the ambient air temp and air density, I stay in Scotland where the air is mostly cold and damp even in the summer time Big Cry
Brian.
Post #203864 21st Jan 2013 4:15pm
Lorryman100
And a OEM reading of 31-32 psi, 218 kPa.
Post #203981 21st Jan 2013 7:36pm
Regard
Should you not remember to subtract barometric pressure from your manifold pressure to get actual boost pressure?
On both readings you took boost pressure only as the Manifold pressure. IF I understand correctly, manifold pressure is actually boost pressure plus barometric pressure together to give you an absolute manifold pressure?
Thus, should your boost pressure not be: 218kPa-99kPa=119kPa. This will equate to 17psi and would sound much more realistic and will fit in exactly with all the readings I've observed before?
Post #203989 21st Jan 2013 7:56pm
Glynparry25
33PSI!!... now that is impressive, lol. 232Kpa is about 18-19psi in boost terms.
Also remember that urbos aren't an exact science. When I was into modified cars I was running a Garrett GT28RS through a Blitz boost modulator which had real time data logging. I had it set to 1.5bar (21ish psi) but in the data logs I had spikes up to 2bar- but only momentarily (less than 0.5 of a second).
Every turbo will do this, and if your ECU notices it there will be a DTA code for it- but 99% of the time it is nothing to worry about- I am sure the ECU will go into limp mode if it was a constant.
Glyn Dog Sheep
Post #203994 21st Jan 2013 8:07pm
Lorryman100
Manifold pressure is just boost pressure + atmospheric pressure located in the manifold at the MAP sensor. To find the true boost from the turbo you need to subtract the atmospheric pressure from the manifold pressure. At sea level this is 14.7 psi so 34 psi - 14.7 psi = 19.3 psi boost pressure, this is a basic interpretation of actual boost without taking into account the actual mass of air entering the engine is directly proportional to the air density, which is proportional to the absolute pressure, and inversely proportional to the absolute temperature. I assumed wrongly that Tim was using his MSV2 and was quoting the manifold absolute pressure recorded in the duratorq live data page. Thumbs Up Razz
Post #204013 21st Jan 2013 8:41pm
Glynparry25
Bri, did you eat an encyclopedia for dinner? Laughing Thumbs Up
Glyn Dog Sheep
Post #204019 21st Jan 2013 8:56pm
Lorryman100
Nah, I had a curry Glyn. Razz Thumbs Up
If you look at the 2.2 EGR version above, the pressure @ the Manifold is 232kPa (33.64 psi). The atmospheric pressure is 96kPa (13.92 psi) which after deducting 96 from 232 leaves 136kPa or 19.72psi and I have just checked the dtc file from the duratorq EMS file from the same session which shows an untested dtc logged for P0234 as well. I commonly get P0234 Over boost and P0299 Under boost as untested dtc's when running with a remap file which don't cause me any concerns. Thumbs Up
Post #204043 21st Jan 2013 9:29pm
bell-auto-services
Depending on which of the 12 boost maps the engine is running on, in standard form you should not see much more than 230kpa total pressure including atmospheric.
Pete
Post #204085 21st Jan 2013 10:15pm
dgardel
Italy
Pete
Mhmmm I need to check mine....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #204149 22nd Jan 2013 12:15am
Tim seymour
Australia
turbo boost
[quote="bell-auto-services"]Depending on which of the 12 boost maps the engine is running on, in standard form you should not see much more than 230kpa total pressure including atmospheric.
Thankyou to all this is a great web site you learn so much cheers Tim Bow down Cess the Taswegian
Post #204174 22nd Jan 2013 8:16am
Tim seymour
Australia
Re: turbo boost
[quote="Tim seymour"]
just thinkig of put a decat pipe on my defender would i need to re do the map and would that help with spiking cheers Tim Cess the Taswegian
Post #205494 26th Jan 2013 12:35pm
