![]() | Home > Technical > TD5 trailer wiring |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 204 ![]() ![]() ![]() |
Hi guys
Any of you know what colours are which for re wiring the towing socket? Ive bought a new kit as old one was passed it. Colours i have on new one are: White Brown Green + Black Red + Black White + Black Red + Grey Black + Grey Grey looks a little purple! I know the standard coulours but cant find any info about this. Make on the cover of the socket is Con Wys.if that helps? Cheers Wil |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6726 ![]() ![]() ![]() |
Is it a LR genuine parts kit or aftermarket?
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
http://www.towingandtrailers.co.uk/shop/132/133/142/index.htm
There's lots of info on google if this isn't quite right. I did mine recently was fairly easy. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
It has the part to plug in to the landrover but its not wired to the socket to which you put the plug in. I bought it from Swansea 4x4 so don't know if it is pattern etc. doesn't say whether it is or not a genuine and no instructions either
Stevie d. If it was in the standard colours I'd be able to do it but as first post says its in different colours
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 ![]() ![]() |
I did this yonks ago and noted it down somewhere/ Will try to look it out but will be tomorrow. You'd think they'd be standardised.
It's not standard wiring colours - either Land Rover or generic 7 pin
Ah, sorry I can't help you as my car is 03 90 and the vehicle wiring colouring will be different between mine and yours. I did do this on my ex RAF 90 years ago but again the wiring colouring would be even more different. Sorry.
Right, here we go:
Pin numbers are for a 7 pin 12N connector. Colour Function Pin # ====================================== White Fog Light 2 Brown Earth 3 Green + Black RH Indicator 4 Red + Black Brake Lights 6 White + Black LH Indicator 1 Red + Grey RH Side Light 5 Black + Grey LH Side Light 7 ![]() ![]() |
Hope you got the kit very cheap as there are no instructions
Martin you are a landrover god!
![]() Ill get on it next, I think I paid about £25 ish. Thank god I've still got my D3! Many thanks for the help guys! |
