![]() | Home > Technical > TD5 trailer wiring |
| willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 204
Hi guys
Any of you know what colours are which for re wiring the towing socket? Ive bought a new kit as old one was passed it. Colours i have on new one are: White Brown Green + Black Red + Black White + Black Red + Grey Black + Grey Grey looks a little purple! I know the standard coulours but cant find any info about this. Make on the cover of the socket is Con Wys.if that helps? Cheers Wil |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
Is it a LR genuine parts kit or aftermarket?
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342
http://www.towingandtrailers.co.uk/shop/132/133/142/index.htm
There's lots of info on google if this isn't quite right. I did mine recently was fairly easy. Steve Discovery 3 HSE BMW 330i Coupe |
It has the part to plug in to the landrover but its not wired to the socket to which you put the plug in. I bought it from Swansea 4x4 so don't know if it is pattern etc. doesn't say whether it is or not a genuine and no instructions either
Stevie d. If it was in the standard colours I'd be able to do it but as first post says its in different colours
| chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264
I did this yonks ago and noted it down somewhere/ Will try to look it out but will be tomorrow. You'd think they'd be standardised.
It's not standard wiring colours - either Land Rover or generic 7 pin
2015 D90 XS SW |
Ah, sorry I can't help you as my car is 03 90 and the vehicle wiring colouring will be different between mine and yours. I did do this on my ex RAF 90 years ago but again the wiring colouring would be even more different. Sorry.
Right, here we go:
Pin numbers are for a 7 pin 12N connector. Colour Function Pin # ====================================== White Fog Light 2 Brown Earth 3 Green + Black RH Indicator 4 Red + Black Brake Lights 6 White + Black LH Indicator 1 Red + Grey RH Side Light 5 Black + Grey LH Side Light 7 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Hope you got the kit very cheap as there are no instructions
2015 D90 XS SW |
Martin you are a landrover god!
Ill get on it next, I think I paid about £25 ish. Thank god I've still got my D3! Many thanks for the help guys! |
