![]() | Home > Maintenance & Modifications > Military Wolf Bumpers |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 533 ![]() |
I’d swop the stand for a screw jack - with ribs on the shaft - far safer and easier to hitch up.
I can't see that the military bumper wouldn't be strong enough for shunting a trailer. You can push a couple of tons of trailer single handed on flat hard ground, I doubt you could bend a military bumper by hand.
For the ultimate in HD front bumpers with shunting ability, this is probably the one to go for. https://www.firstfour.co.uk/defender-heavy...ocket.html You can have a drop plate and slot it in for moving caravans or what ever, another with a Nato hitch and another with a shackle on it for recoveries if you need it. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
You need to modify the grille: ![]() Click image to enlarge |
That’s the one Diesel Jim
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
I have this for sale - fits perfectly (but not with Aircon grill I guess)
http://www.defender2.net/forum/topic61685.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
I like that - 5mm steel plus one of these and a NATO hitch would be perfect. |
and if you fit a 2" receiver on the back you can just swap it from front to rear plus you can remove the towbar if you want to do more extreme off roading.
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 ![]() ![]() ![]() |
even the issued bumper is quite thin, 3.5mm from memory. i got a copy made in 5mm from dixon fabrication and fitted rotating shackles to the front face. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
the towing eye on a sankey mkIII trailer will not fit into a mil bumper centre recovery slot (which is intended only for straight bar road towing) I have an adapter made by a friend which i use for shunting my sankey trailer 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
