Home > Maintenance & Modifications > Military Wolf Bumpers
Page 2 of 2 <12
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
There's no nose jack or jockey wheel on the narrow track comms body (aka BDR) Sankeys - just a swing down strut. It is adjustable for length but not whilst bearing any weight because its just one tube inside another, locked off with a wing-headed bolt.
Post #720572 30th Jul 2018 10:29pm
Grouse
I’d swop the stand for a screw jack - with ribs on the shaft - far safer and easier to hitch up.
Post #720576 30th Jul 2018 10:40pm
zsd-puma
I can't see that the military bumper wouldn't be strong enough for shunting a trailer. You can push a couple of tons of trailer single handed on flat hard ground, I doubt you could bend a military bumper by hand.
For the ultimate in HD front bumpers with shunting ability, this is probably the one to go for. https://www.firstfour.co.uk/defender-heavy...ocket.html
You can have a drop plate and slot it in for moving caravans or what ever, another with a Nato hitch and another with a shackle on it for recoveries if you need it.
Post #720593 31st Jul 2018 6:38am
Intercept wrote:
Thanks Mash.
So my next question is whether the hitch pin can be removed if a military bumper is fitted to a Defender with an aircon grille...
You need to modify the grille:
Post #720597 31st Jul 2018 7:20am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
That’s the one Diesel Jim Thumbs Up a lot of the BFAs also have this mod to allow use of the front bumper pin. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #720603 31st Jul 2018 8:22am
MartinK
I have this for sale - fits perfectly (but not with Aircon grill I guess)
http://www.defender2.net/forum/topic61685.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #720621 31st Jul 2018 9:31am
Intercept
I like that - 5mm steel plus one of these and a NATO hitch would be perfect.
Post #720623 31st Jul 2018 9:36am
zsd-puma
and if you fit a 2" receiver on the back you can just swap it from front to rear plus you can remove the towbar if you want to do more extreme off roading.
Post #720671 31st Jul 2018 1:05pm
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
Re: Military Wolf Bumpers
stevie d wrote:
Hi,
Anyone know where I can get a good quality Military bumper?
I have seen a few for sale but can't seem to find out whether they are 'heavy duty' or cheap copies.
I spoke to John Craddocks today, but they had know idea what the ones they were selling were like??
Thanks,
Steve Thumbs Up
even the issued bumper is quite thin, 3.5mm from memory. i got a copy made in 5mm from dixon fabrication and fitted rotating shackles to the front face. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #724665 21st Aug 2018 7:56pm
foxhound
Intercept wrote:
Intercept wrote:
I was wondering whether the military version of the bumper with the pin is able to accept the NATO lunette
Some forums have stated that they're not strong enough for pushing - that would be my need if anyone can confirm whether the NATO ring/lunette will fit into the receptacle. But I'd only be pushing a 3/4 tonne Sankey:
the towing eye on a sankey mkIII trailer will not fit into a mil bumper centre recovery slot (which is intended only for straight bar road towing)
I have an adapter made by a friend which i use for shunting my sankey trailer 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #727472 6th Sep 2018 7:43am
Page 2 of 2 <12
