![]() | Home > Maintenance & Modifications > Door theft protection, |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
unless your door bolts are S/S why not use the those super magnetic Ball bearings?
then cover with coloured silicone sealant
You'd never get the solder to take! Page 2..... ![]() http://www.defender2.net/forum/topic8589-15.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Ric Member Since: 04 Nov 2012 Location: South Yorkshire Posts: 209 ![]() ![]() ![]() |
Thanks.
another option would be just to drill out the inside of the bolt heads. if i need to get them off then i'd have to dremel the sides or a slit for a flat head screw driver? its only a car! |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
Might dremelling out a slot for a flat head screw diver not be a tad difficult when the heads are recessed?
I think just filling the recess with construction strength silicone would be enough of a deterrent. Would take them too long to scrape it out. |
Heads prominent enough, only need a small slit to knock a driver in,
Probably easier than resin. With a silicon surely you'll still be able to knock a torx bit in there! its only a car! |
^^^Not a chance!
The heads are indeed recessed unless you've got after market bolts as shown on the photo. The two bolts on the door itself are recessed at difeferent depths and you would not get a cutting tool in there to cut a slot without damaging the hinge itself. Silicon would have to be meticulously picked out to get a torx bit in there believe me. The idea is as a deterrent as any determined thief will be able to get in several ways very easily. ![]() The 'layered approach' is best in my view.....Taken from another thread..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Silicon or drilling out heads is no real deterrent ... you can readily buy adaptors for removing knackered headed screws/allen bolts/torx bolts etc that fit a cordless drill/impact gun and cut into the remaining material to unscrew .... if your scum comes prepared then silicon or drilled out head is only a mild delaying factor.
Stainless BB superglued into the head works best, very difficult to prize out and owing to the shape/material they are almost impossible to overcome without spending a lot of time .... ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18002 ![]() ![]() ![]() |
Unless you do the ball-bearing trick it would be easy enough to drill the head off the fastener, the remove the door, then use a quality stud extractor to remove the residue of the bolts. This is time-consuming but simple and I imagine is an effective deterrent to anyone thinking of just stealing the doors, since drilling out enough to get the doors will take a while. I doubt it will deter theft of the vehicle for subsequent stripping when time isn't such an issue.
If you have inserted ball-bearings it is likely that you'll only get the doors off by extracting the hinge-pins or sacrificing the hinges. It would not be at all easy! |
K9F
Lol that's me thinking from my living room, & not been next to the car. Your right with the screws on the door side. That would take a lot of concentration and disc changing to get at them. On the silicon front, are you talking about a different product to what would be used to seal window frames etc. If so, do you have a brand name? When the layered approach is spoken about, is it intended for the same goal, ie solely to pinch the doors or the steel the car, How could you layer the theft of say the doors, would it just be one ball bearing in each side for anti drill, and silicon in the remainder. Obviously on the car theft front, it's things like: mechanical (pedal cover) then immobilisers, then trackers etc Thanks for the comments and help its only a car! |
Blackwolf & Dave-h
Thanks, I missed your posts before when I replied to k9f I've plenty to think about, It's great living where defenders are treated as pick n mix ![]() |
I certainly do have a brand name seeing as you asked....(forum joke as I have mentioned it many times in other threads).... SIKAFLEX 29i Marine Grade.... http://www.bosunbobs.com/en/Sika-Sikaflex-...tAodcmAAdw Picture paints 100 words..... ![]() Click image to enlarge The recessed bolts by the time you seal the bearings in you can't even see them.... ![]() Treat every day as if it is your last....one day you will be right!! |
Cheers, your right with the picture,
Neat job What size balls do you have? ![]() |
Ooh, well thats a bit forthcoming isn't it ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
